2013: I'd like to try another turbo. Really? Really. I've been thinking of a Ko3 as would be found on our Audi TT. Thats a smaller turbo, seems to perform well on the 1.8L TT motor. They were out there on all manner of 1.8T motor from Audi and VW, so there may be some used options cheep.
What turbo do you have now? Where do you see full boost and how much PSI do you run?
I am a turbo guy, my Audi 1.8T's KO3 I replaced with a GT28R, which I replaced with a Comp Turbo CTB5356.
The KO3 is to small of a turbo for even just the 1.8t, Full boost under 2k, Boost starts to taper off after 5k, Shift at 5.5k Max power ~ 160AWHP (20psi).
The GT28R was a perfect sized turbo for the 1.8T as an autox'er or daily, Full boost under 2500, boost doesnt taper off even at 7200rpms shift at 7200 rpm's every time, max power 275AWHP(20psi)(This turbo gave INSTANT full boost above 4krpm's, aka any situation in an autox.).
The CTB5356 is a bit large, but with the increase in turbo technology its a very good sized turbo for daily driving, however a tad laggy for instant boost at autox. I would consider this an awesome track turbo. This turbo is designed to run extremely high boost pressures (35PSI) and still be efficient, which was the reason why I chose it. I run only 10psi at the moment and it makes the same power as the GT28R when I ran 20psi. Full (Low) boost ~4krpm, probably 4500 at high boost, boost probably wont taper off till 8500 rpms but my tune doesnt go past 7200 currently. I anticipate well over 400AWHP(25psi) when I crank the boost up. If I ran C16 and spent some time on the head I might see 500AWHP(35psi), but I dont think I'll get to that point any time soon.
I am a big fan of the right sized turbo for the job. You might want to look at the SR20DET turbo's that come stock. Some of them are ball bearing, but most are journal bearing and can be had CHEAP.
Small turbo's make excess heat. Excess heat means detonation. Get yourself a nicely sized turbo. I wouldnt throw a KO3 on anything more than a 1L Geo engine.
Also Audi TT's (225hp model) used a KO4, the 180hp model used a KO3. The KO3 has stopped being used in most engines due to its small size, the KO4 is almost the exact same size but is more efficient, however more desirable. Consider that if you REALLY need to go with a small turbo.
