QUOTE(Pat Garvey @ Feb 28 2009, 06:20 PM)
QUOTE(tod914 @ Feb 27 2009, 09:14 PM)
Yugo's haven't fully reached their due status Pat. Maybe be a trend setter and get one of those.
Tod,
Thanks, but Yugo get one first!
Pat
Pat ....how about some questions about what makes the wheels stop??
...or is there a specific post on brake systems somewhere here?
I'm trying to collect the parts necessary to get my `73 2L back on the road after being dry stored in my SoCal garage since 5/85 (+/- 24 years!) - both Mech & Body, and my preference is to stay OEM/OES or close to stock.
So I want to post questions on various systems, components & parts here -
IF this is the appropriate place, or should I look to other areas on this bbs??? Please let me know if not &/or where I might get more & better responses to a particular topic.
That said,
I'm looking at brake stuff this week. - for STREET driving use, without any...
A few
Brake System Questions, so I can take advantage of Performance Products 15% off sale this week:
1.)
First & Foremost - are Performance Products prices
typically good competitive pricing?? ....&
are their weekly specials & discounts are worth jumping at?...or can I do better just shopping around? Dr. 914 - George - feel free to weigh in on your Auto Atlanta stock! 2.)
Brake Pads - OEM or ???? by whom? - STREET use
> which for improved braking?
> which for best life?
> which for least "squeal"?
> which don't have asbestos? (a no-no in CA & PBR has it!)
> ratings for: ATE, Jurid, Textar, Pagid, Mintex, Hawk, PBR, others?
3.)
Stainless vs OEM Rubber Brake Lines? > worth the extra price?
> longer life? ...if so, how much longer lasting?
> what is "shelf life" for each in terms of rubber/teflon/silicone?
...I hope to get them installed in `09, but it might be next year, what with all of the other stuff to be done! > whose are best? ...Weltmeister? ...others?
4.)
Master Cylinders - 914-4's 17mm -or- 914-6's 19mm?? (OEM only)
> 19mm are straight bolt-in substitute - correct?
> any steel lines, connectors or anything else need to be changed with 19mm?
> how much improvement 17 > 19mm?
....& for $45 less @ 19mm! > any issues, concerns & problems in using 19mm?
> what is "shelf life" in terms of their rubber/teflon/silicone "innards"?
I hope to get them in 2009/2010, but don't want them deteriorating on my shelf! > any external rubber lines/parts to also replace on MC's? ...any available in SS?
> safety issues & viability of rebuilding current MC which has sat 24 yrs.?
...for safety reasons - I prefer it OEM/OES new or reman. unit (in case of internal rust/pitting/etc.)5.)
Brake Fluids --
> Porsche OEM vs. which others? - for STREET use
> How much do I need for complete change-over & bleeding? - # of oz. or ml & # of cans/bottles?
> what is "shelf life" if left
un-opened until rebuild? - +/- 09/2010?
6.)
Disk Calipers -- (they're not on sale now for 914s, but for future Ref.)
> new vs remanufactured vs "rebuilt"
> are OEM &/or OES now NLA?
...or if still available - where?? Front? & Rear?
> best mfgr source(s) for OEM Re-mans?
> what & where are the retail sources for above alts?
I hope to get them in 2009/2010, but don't want them deteriorating on my shelf! > safety issues & viability of rebuilding current Calipers which have sat 24 yrs.?
...for safety reasons - I prefer it OEM/OES new or reman. unit (in case of internal rust/pitting/etc.) > best caliper rebuild kits & mfgrs?
...& is the shelf life of the rubber parts 2009-2010 or more?7.)
914 Proportioning Valves -- (they're not on sale now for 914s, but for future Ref.)
> are OEM &/or OES still available? ...&/or OEM/OES Remans?
> any better alternative p.valves to elim. "spongy pedal"?
> how are the adjustable ones (like JWest)?? ...& how ahrd to adjust to get right for STREET use??
or are they more of a pain in the A than they're worth???? > what & where are the sources for above alts?
I'm not interested in replacing it with a "Tee", cuz it serves the function to prevent real lock-up & resulting spin-out or swapping back-to-front when you have to brake hard!!Any other Brake System Tips? Note that I'll hold off on buying anything without a "safe" shelf life thru 2010, until the actual time I'll be doing the brake system - sale or not! ... just to avoid those
moments!
I've also got the post on researching my 914 where you've replied before - & where I also posted this (but the replies are slow in coming), so I'll try it here too. My other post is at:
http://www.914world.com/bbs2/index.php?sho...=93838&st=0 Thanx in advance guys & gals!
Tom
Second, you ask a LOT of questions! We like that, though it will take some time to muddle through them. This thread is as good as any other, since it's related.
So.... first I'll wiegh in on something you haven't posed - calipers!
Your 914, since it's been sitting for so long, is most probably going to need the calipers rebuilt before anything else. Unless you are a major wrench, I'd get in contact with Eric Shea for rebuilds. His are the best for funtionality & presence.
