fiid
Oct 25 2005, 10:00 AM
This is the center console guage cluster. I'm going to have to make a new panel for it.
Right now I have the trick VDO oil pressure setup (with warning light as well) from the 914.
Coolant temp (although it doesnt' seem to be reading like it did on the bench
and Voltage.
I have a small fuel guage to go down there and a boost pressure guage as well.
fiid
Oct 25 2005, 10:04 AM
This is the idle air control valve. It's a solenoid that can pull open and shut. The shut side has a resistor pack to ground, and the megasquirt controls the open side. The open and shut sides fight with each other to make a fully adjustable idle, and the MS will target a given RPM - so you enter that RPM with a laptop.
fiid
Oct 25 2005, 10:06 AM
fiid
Oct 25 2005, 10:09 AM
The Innovate LC-1. Awesome piece of kit.
fiid
Oct 25 2005, 10:12 AM
This nest is Bowlsby's worst nightmare
This is the megasquirt and the EDIS module and also the air filters. I used a small secondary filter for the idle air since it's tricky to route a 3/4" hose through a 1"radius turn for 90 degrees.
TonyAKAVW
Oct 25 2005, 11:23 AM
LOOKING GOOD!!! Well, that wiring could use some attention, but otherwise, congrats on getting it out of the garage under its own power!
Are you planning on going back to the dual turbo setup with this car at some point, or just keeping the single turbo?
-Tony
fiid
Oct 25 2005, 11:45 AM
I think I'm going to stay single turbo. The aftermarket for the single turbo is ripe, and even people that have had very good experiences with the twin turbo setup have still gone back to the single turbo setup.
If I get to a point where I need more power I might go to a ball bearing turbo or something, but there's plenty of options and plenty of things to do before I need to go that far
airsix
Oct 25 2005, 02:30 PM
I'm just very relieved to see that I'm not the only (turbo) guy running intake parts that came from Home Depot.
Just kidding. Fiid, I'm very excited to see you making this progress. I was bumbed when I thought you had dumped the project. Keep posting - this is great stuff.
-Ben M.
fiid
Oct 25 2005, 02:37 PM
Thanks! I'm glad I stuck with it now - it's really keeping me awake at night thinking of driving it to work a couple of times a week.
LOL. ABS is cheap, and easy to put together, seals well, and you can screw anything into it. I pressure tested the fittings and got them to hold 30lbs (you have to do the clamps up REALLY tight), so they ought to be sufficient for 15lbs of turbo boost
All the ports (i.e. where that temp sensor is screwed in) were done by drilling a hole, making it the right size and then just screwing the right npt thread into it.
I realise it's not going to work forever: What do you guys recommend for a replacement strategy?
SpecialK
Oct 25 2005, 03:23 PM
What are you expecting for inlet temps? I think that ABS starts to deform around 185F or something like that.
fiid
Oct 25 2005, 04:58 PM
QUOTE (Buzzard1 @ Oct 25 2005, 01:23 PM) |
What are you expecting for inlet temps? I think that ABS starts to deform around 185F or something like that. |
Good to know. I wouldn't expect the intake to get hotter than like 130-140 degrees, but I haven't done any math on that...
airsix
Oct 25 2005, 05:32 PM
QUOTE (fiid @ Oct 25 2005, 02:58 PM) |
Good to know. I wouldn't expect the intake to get hotter than like 130-140 degrees, but I haven't done any math on that... |
My datalog showed I hit 194 F for a few seconds one day last year. (No intercooler)
-Ben M.
fiid
Oct 25 2005, 05:36 PM
how much boostola are you running?
airsix
Oct 25 2005, 09:03 PM
QUOTE (fiid @ Oct 25 2005, 03:36 PM) |
how much boostola are you running? |
Well, I messed up the linkage on my wastegate around that time and it didn't have enough travel so the boost would creep if I stayed on it beyond 3rd gear. I hit 2.0 bar a couple of times before I figured out what was happening and fixed the wastegate linkage.
-Ben M.
fiid
Oct 26 2005, 12:59 AM
I logged 147 degrees this evening with only 6 lbs of boost. I see why air-to-air intercoolers work
I need to find a place that does turbo projects
mongrel-gs
Oct 27 2005, 12:22 PM
Thanks for posting the pic of the idle air control solenoid, it reminded me that I should probably have that hooked up. Idles much better now!
Glad to see you project is on the road!
Evan
fiid
Oct 31 2005, 02:41 PM
No pics this weekend - but lots of progress.
I have been fighting with the cooling system a little bit. It took me a long time to figure out why it would boil over every time. I was truly beginning to appreciate the simplicity of an aircooled engine when ..... I finally figured it out.
My coolant hose was within 1" of the header. The radiant heat from the header was boiling the coolant in the hose, before the engine was warmed up and the coolant was actually flowing to the radiator, so it would boil over before the fans kicked in or any radiator flow was happening at all.
This was cured by cable-tieing the hose back out of the way - which seems to work nicely.
Now on to the next problem - the engine seems to "miss" occasionally when I get up above 3k RPM. I'm thinking this could be caused by the EDIS wheel reading getting interference - or perhaps something more sinister.
I got some small taste of available power - and it was... NICE. I don't think I have more than half of what will be available post tuning and proper boost control, however.
ClayPerrine
Oct 31 2005, 02:44 PM
I hope the engine runs better than it looks, 'cause it looks like an electrician's scrap bin in there!!!!!
fiid
Oct 31 2005, 02:46 PM
Thanks! It's a bit of a mess, but I have made virtually no effort towards tidying it up. The circuits in play may change more so I'm just making sure there's sufficient room to move stuff around again if I need to.
ClayPerrine
Oct 31 2005, 02:52 PM
I hope you aren't offended by my comment.. I don't mean anything by it. I am a bit obsessive when it comes to wiring, in both my professional life and my hobbies. My tools get scattered over the garage, my parts are all over the place, but wiring... well, I can't STAND a rats nest of wires. I have to straighten them out and make them neat and tidy. I am just weird that way........
fiid
Oct 31 2005, 03:11 PM
No offense taken at all. The car is a complete trainwreck in terms of wiring. As soon as everything is running right I'll start worrying about that, welding the trunk back in (turns out I can have a more or less complete rear trunk
and paint.
Need to get the GT flares on as well at some point. Many miles left to travel.
fiid
Nov 16 2005, 10:45 AM
Latest News:
I picked up an oscilloscope on craigslist about a week ago which has been really useful. Firstly - I found out that my idle air control was jammed at full open because I bolted a power transistor directly to the case of the megasquirt - grounding out a connection that wasn't supposed to be grounded. After a bit more work - the idle air is working perfectly - it will sit there at almost exactly 800RPM once it's warmed up. I still have a bit more tuning work to do to get the startup value correct, but it's looking pretty good at this point.
I discovered that I had the megasquirt configured incorrectly for the ignition module. This meant that my timing was stuck at 10o BTDC. I think this was the cause of the misfire - basically - the mixture was burning too late and spoiling all the fun.
All this came together last night when I spent some time to clean up some of my wiring (it's not perfect yet, but I removed about 5-10 feet of excess wire which was just sitting in a crowsnest, so it's looking a lot neater.
I fired it up, and took it for a spin and had a really nice experience - asides from being a little loud (perpetuated by the almost total lack of sound deadening material and no engine lid) the car ran really well and pulled strong once I got it up to like 2krpm and hard on the gas. I took it up to 5k and it was running nicely. My redline should be at 7k (I think I'm going to split an eardrum.
Me = Happy.
The 911 suspension on the front end is working really nicely too (thanks to Steve/ShogunEagle). Brakes are a lot stronger thanks to new rotors and pads front and rear, and removal of the stock prop valve. I have an
A-caliper front end on the car, and the rear is stock 5-lug.
I also cut a radiator hole in the front bumper and got some weldable expanded steel (almost matches the engine lid) to go in there.
I'll post some pics when I take some more.
eric914
Nov 16 2005, 12:42 PM
I am proceeding on a similar route as you. I have a EJ20G single turbo motor that I intend to Squirt. Would you mind sharing your fuel and spark maps and how you chose to implement COP? Any insight would be helpful. I will be tackling this after the holiday season is over.
fiid
Nov 16 2005, 01:06 PM
QUOTE (eric914 @ Nov 16 2005, 10:42 AM) |
I am proceeding on a similar route as you. I have a EJ20G single turbo motor that I intend to Squirt. Would you mind sharing your fuel and spark maps and how you chose to implement COP? Any insight would be helpful. I will be tackling this after the holiday season is over. |
You're welcome to all the info I have, but my maps really aren't very developed yet. I'm currently running the car on 87 (bad decision - I'm changing to premium as soon as I use up the current tank), and really haven't spent all that much time tuning the thing.
I'm running a ford EDIS module for spark - seems to work really well - I am using the ford coilpack and plug wires. It's a wasted spark setup, instead of Coil on plug. I do have a set of coils for COP but they don't have ignitors, so it will take extra electronics to get that going.
jsteele22
Nov 17 2005, 11:54 AM
Sounds fun ! I'm curious about what "redline" means. I always thought it was just a limit set by the strength of the engine components - go above redline and somethings gonna break. Do you mean the RPM where the engine is at max power ?
BTW, those power transistors with the heat sink connected to a non-ground terminal are a pain. If it is running hot, you can buy (from Digikey, fer example) a thin pad to electrically insulate the transistor from a grounded heat sink. Do a search for "heat sink pad", and (I assume) TO-220 size. Under a buck, and if it keeps the transistor from burning out once, probably worth it.
fiid
Nov 17 2005, 03:27 PM
I've read in a couple of places that the stock redline on this engine is 7k, but I've never seen a USDM subaru with a 7k redline, so I figured I might set the rev limiter a little lower (6500) just to keep the engine running a little longer. It's taken me so long to get this far I don't really want to break it
Anyone know what the redline on the WRX is?
I need to mount the transistor properly at some point, but it doesn't get even warm right now. It's on a plastic stand-off post that is double sided stickytaped to the PCB. Now I talk about it - I instantly regret my decision to do that.
jsteele22
Nov 17 2005, 04:12 PM
QUOTE (fiid @ Nov 17 2005, 02:27 PM) |
I need to mount the transistor properly at some point, but it doesn't get even warm right now. It's on a plastic stand-off post that is double sided stickytaped to the PCB. Now I talk about it - I instantly regret my decision to do that. |
Actually, I realized after I posted that if the transistor is only for driving the IAC, it probably wouldn't get that hot. But ya never know....
fiid
Nov 20 2005, 09:26 PM
Hey all,
Jeff Keyser came over today and we did some tweaking and fixed some little annoyances with the car...
1. We spent some time just tweaking the idle, and trying to get the mixture and Idle Air Control functioning properly.
2. We fiex the lsatch for the rear trunklid. My Latch has never worked right, but now it does actually hold the lid down, so it doesn't bang when I go over bumps anymore.
3. We mounted the front bumper with cutout and mesh welded in. It looks pretty nice... I'm quite happy.
We then went for a bit of a spin. Jeff was able to iron out a bunch of issues with the fuel map and we discovered that even though I am only running 6psi boost - it's still wickedly quick.
The next problem I have is that my 205s on 7s don't fit under the rear fenders and rub a little bit during cornering. Time to fit those GT flares
So.... fast.....
fiid
Nov 20 2005, 09:28 PM
Oh - I also realised it's a daft idea to run the car on 87 octane, so I put in some octane booster. I expect to be running it on premium from now on.
banksyinoz
Nov 21 2005, 01:55 AM
the sti conversion ive posted pics of has an 8k redline/limmiter stock its an 04 so the wrx would mostlikely be 6.5-7k
mightyohm
Nov 21 2005, 11:11 PM
I had a great time at Fiid's yesterday. For anyone who has never seen it, Megasquirt is COOL. His engine purrs at idle and really moves on the throttle, and it's not anywhere close to being tuned yet, plus he has it dialed down to 6 psi max boost!!! His car makes me think dirty thoughts about putting my own car on the chopping block for a JDM Subie conversion with Megasquirt...
The best part is, it still sounds vaugely like a 914, but without all clacking valves! I was really impressed with Fiid's mastery of the fuel injection on that car and his custom turbo plumbing and cooling system. Hopefully some of the local guys will get to see it at the next breakfast!
fiid
Nov 22 2005, 03:52 AM
Thanks Jeff!
It's awesome to have a little more experience with engines around. I don't really know crap about fuel mixtures or what the sounds, smells and look of spark plugs ought to be. I've spent most of my time futzing with cars trying to fix broken things and not on tuning.
I'm totally stoked to get my boost level up. The stock WRX runs at 13-15psi boost, so I've got a long ways to go; and theres going to be a lot of power once that gets lit up
I'm going to have scads of family around for thanksgiving but should be wrenching the weekend after - trying to get the car ready to head down to the Brunch at iHop.
DNHunt
Nov 22 2005, 08:27 AM
Fiid
That sounds great. When you get to tuning the AF mixture look into the new
Autotune feature in Megatune. I have't tried it yet but the comments sound encouraging. You're going to have a rocket.
Dave
fiid
Nov 22 2005, 11:02 AM
WHOA!!! That is TOO COOL. Definately going to give that a try!!!
Thanks for the link Dave!!
jsteele22
Nov 22 2005, 11:19 AM
Hey fiid,
This is really exciting to watch. I'm (still....) waiting for my EJ25 to come, and I've been reading up on MegaSquirt. Sounds like you've got plenty of eyes over your shoulder, but I just wanted to mention something -- sorry if this is way too obvious. Be VERY careful about detonation (pinging). Although MegaSquirt has an input for a knock sensor, the latest code that I've looked at doesn't actually do anything with it. So if you raise boost and start pinging, MS won't do anything to stop it. Since this can easily destroy your engine, you might want to hold off on raising the boost until you gain more experience getting the lower pressure part of the map dialed in. Especially if you test out AutoTune (which does sound totally cool, BTW.)
Man, you've come a looong way on this build. Have an awesome ride.
(the other) Jeff
fiid
Nov 22 2005, 11:31 AM
I'm running the Megasquirt-N-Spark Extra codebase. The knock sensor setup is adjustable, and we (JeffK and I) think that we haven't actually had any detonation yet, despite the sensor picking it up. We're showing a logged 2 degree retard on the first knock followed by extra retard degrees for subsequent knocks; I'm reasonably sure it is working right since that's the described behaviour for the code.
Thanks for bringing this up though - I definately don't want to do any damage to this engine, and it's something I'm acutely aware (and scared of). I'm thinking some dyno time is going to be necessary to make sure the whole range of the map is running right and in the safe zone.
jsteele22
Nov 22 2005, 11:51 AM
Cool. I won't worry any more. I was looking at MegaSquirt-II, and I gather it doesn't have as much built into it yet as the older code. You just had me a bit concerned when you said "I don't really know crap about fuel mixtures" follwed by "I'm totally stoked to get my boost level up."
BTW, how is that Suby in terms of turbo lag ? I drive a '97 Saab 900 SE turbo, and it's awesome on the highway (and two-lane country roads...) but I'm a little disappointed in my normal stoplight-to-stoplight driving. Do you get decent acceleration from a standstill to, say, 20 MPH ?
lapuwali
Nov 22 2005, 01:33 PM
I certainly hope you drive this thing to the breakfast. I've been really looking forward to seeing it.
jsteele22
Nov 22 2005, 02:29 PM
QUOTE (fiid @ Nov 22 2005, 12:09 PM) |
[ I'm also kind of happy about this though since it means that I get the revs up a bit before the real power comes which is likely to be the saving grace for my 901 transmission. Once the boost does kick in, the thing just takes off.
Yeah, that part is pretty cool. Takes a little getting used to when you start from rest and accelerate around a wide corner. Wish I could make it to that breakfast...
fiid
Nov 22 2005, 06:08 PM
I've been talking with a guy (Big thanks if you're reading!) in the UK who used to have the twin turbo legacy that this engine came out of. He's provided a lot of great info on the stock ECU which I should be able to leverage in my tuning. He had the following to say about the engine:
QUOTE |
If you ever make 21psi you should be 350 ftlbs ish. At that boost a single detonation event could and probably will fracture a piston between the ring lands. I speak from experience.
Looking at your piccies it looks like you have a 250 ps engine from a bg5a legacy - ie like my old one. It should make for good performance! If you tune it it will be, well, scary!
jsteele22
Nov 23 2005, 12:40 PM
QUOTE (fiid @ Nov 22 2005, 05:08 PM) |
If you ever make 21psi you should be 350 ftlbs ish. At that boost a single detonation event could and probably will fracture a piston between the ring lands. I speak from experience. |
Cool. Then you wouldn't need to bother with the knock sensor....
fiid
Nov 23 2005, 04:32 PM
Yeah - no $#!+.
(Fiid sits at side of road waiting for a tow).... "Guess it knocked!".
mightyohm
Nov 23 2005, 05:25 PM
Does the knock sensor board in the megasquirt interface with the stock Subaru knock sensor on the engine? Is the megasquirt board thought of as a reliable solution or is it experimental? I think the only safe way to avoid knock is to keep your advance and boost at sane levels, and err on the side of rich for the AFR. Maybe you could find the advance vs rpm and map curves for a stock engine?
fiid
Nov 23 2005, 05:32 PM
Yah. I think NOT running 21 pounds is a great idea - 350ftlbs from a 4 cyl will make short work of a 901, and besides. I'd settle for 250-280.
The knock solution I have is somewhat experimental.
I now have the stock AFR target table and advance tables, so I know what ballpark the engine is intended to run in although they aren't quite the same axis as the megasquirt (Load instead of MAP, etc).
I think by staying relatively conservative there's a lot of success and happiness to be had. Next up though is Muellers 2x4 & Sledge fender tuning....
:bfh:
soloracer
Nov 23 2005, 05:35 PM
Are you using a wide band O2 sensor to datalog your mixtures? If not I suggest getting an Innovate LM-1. It's a very good unit and will be invaluable during tuning.
fiid
Nov 23 2005, 05:36 PM
I have an LC-1 - I violently agree - they are awesome. I do my datalogging off the Megasquirt.
fiid
Dec 5 2005, 01:41 PM
fiid
Mar 10 2006, 08:35 PM
Minor update - did a bunch of work today to try and get the car ready for AX tomorrow. Good news is I think I can run it!!!
Did a bunch of driving and it looks like the cooling system is working fine. I think a lot of my problem might have been caused by various air bubbles in the cooling system.
I'll try and get an in-car video soon!
P.S. Experienced throttle steer for the first time today
Woohoo.
fiid
Oh - yeah - in other news - it's also running Megasquirt II now - which seems to be very smooth and running well!
