Got the rear bracket done, cables installed, shifter installed and the car shifts. It took a little while to get it adjusted, then I took it all apart to paint it. The shift is firm and positive. The only tweeking I may do is to widen the neutral gate. I need to drive it first. If I were to do it again, the slip fitter should be milled from billet steel and I would get a heim that could articulate a little more on the end. I milled down some small washers on the heim/cable connection to help prevent binding. The cable system gets rid of all the slop in the rod system. The play left over is the shift console to shift fork slop. It would take some welding and machine work inside the tranny to remove all slop. All in all, the shifting is much improved. I will get it back on the road this weekend and try it out...
The bracket turned out how I pictured it...
Click to view attachmentThe top bracket was welded at a compound angle. I installed the cable to the bracked and console and tacked in place...
Click to view attachmentBottom view. Slip fitter is not pretty, but it works great. Maybe Racer Chris can mill a pretty one up for me...
Click to view attachmentYou can see the washers added to increase movement...
Click to view attachmentFound this cool clip at HD for $0.75 and a 3/16 pin ($1.07). I welded the pin on and then hardend the piece.
