Ok, I am on the final push towards the end. I have dyno time schedules for Friday, Feb 18th at Cobb Tuning Surgeline. Still waiting on the flywheel, but I can get everything else prepared in advance.
Reprogrammed the dash for a little pre-race inspiration.
I also wired up the oil pressure, oil temp, fuel pressure, and water temp sensors to monitor on the dash.
For radiator venting thru the hood, I purchased two louvered panels. These things were pricey and I was less than impressed with the quality. However, they will serve a purpose and I have to remind myself that this is just a race car.
Here are the panels in the approximate location on the hood.
I took the hood up to JP's shop to make the cutouts. Fortunately I was able to get JP off his butt to help cut the hood. Notice that he can't do anything without a cig hangin out of his mouth.
Here are the panels bonded to the back of the hood and in place on the car.
Side view, they are just under the 1" height restriction as per SCCA.
Looking down into the hood you can see the radiator and fan.
On the backside, you can see the area of the core mat we had to remove to bond directly to the backside of the hood. Added an additional layer of epoxy to the backside for strength.
I also was able to put a gallon of fuel in and test the system...good idea that I did this now as I found a pinched injector o-ring and had to get a new set on order. It was fun to have 45psi of fuel squirting out of the fuel rail.
-Britain
