I want to give you guys a quick update as I prepare for the SCCA Nationals in Lincoln.
At the Packwood NT, we continued to struggle with lack of rear grip. Although I have tried several adjustments, springs, sway bars, etc., I just can't get the balance like I want it. If I compensate for the rear grip, then the car suffers from understeer. If I adjust that out, I have trouble keeping the rear end under control. Either way, the current set-up was just not working.
Therefore, short of completely changing the suspension to something from the 21st century (that is coming soon), I decided to take my tire contingency winnings and get a set of Hoosier Radials. For reference, my old set-up was 23.0x9.5x15 cantilever fronts and 22.0x10.0x16 rears, both bias ply in R35B compound. My new set-up are 23.0x10.0x15 R25B fronts and 23.5x12x16 R75 rears. The thought here is that the softer fronts will allow them to heat up faster and provide good front grip and the rears will last longer and provide more mechanical grip from the wider width.
In order to fit the larger wheel tires properly, I was forced to rebuild the rear wheels. I first disassembled the 3-piece wheels.
Unfortunately the older wheel barrels were not BBS and where actually welded together at the seam. I therefore had to source 5" inner halves and 7" outer halves to make this work.
Here are the wheels assembled. Gotta love the "dish"
Now I was able to mount them to the car and see exactly how far they were going to extend past the fenders.
For the fender profile, I decided to follow the profile of the tire instead of maintaining the fender profile. Here is my quick and dirty wheel profiling tool.
The first cut was actually the hardest part. This isn't the best picture of the procedure that I used because I actually created a pattern out of hardboard as a reference while I cut.
Here is the approximate location of the rear tire, there is about 2" or clearance all around.
The 12" tires extend out about 1.5", hence the reason to cut the rear fenders.
