Now on to the rear suspension.
First up was to cut the front half of the trunk floor and shock towers out.
Next we cut out the old trailing arm suspension ears.
After lots and lots of grinding, this is what we ended up with...lots of space to work with.
To start, we constructed a jig that runs the entire length of the car and reference the mounting locations for the rear suspension to the front suspension. This allows us to put everything in alignment front and rear and side to side.
Side view of the location of the rear suspension in reference to the transmission. The custom axles are going to be around 23" long and require a custom outer stub-axle to be machined.
Here you can see the jig running from the front suspension to the rear.
The rear sub-frame will be attached to the car in 6 locations and will hold the complete rear suspension as well as the engine and transmission. This is the lower bar going into place. You can see in the foreground the bung that was welded into the chassis.
This is Teddy, the owner and machinist at Mavrik Motorsports, the shop where I am constructing this contraption. He is notching the tubing for the rear sub-frame.
Lower sub-frame bar going into place.
I will be back down there this coming Sat. and the plan is to complete the rear sub-frame and start working on the new cage.
-Britain
