I am extremely swamped with school work this weekend, been working on senior project stuff from friday morning till now, basically the entire time!
Therefore i cant do any physical work on the teener for a few days... but i can sure surf the forums on my 5 min breaks here and there!
But over these past two days i received two packages in the mail
First package was from superbrightLEDs.com, ordered my red LED strip for third brake light, after i saw Dougs in person last weekend i was 100% on board with that product. it was $11 for the 50cm strip, cant beat that! While i was making the order from them i also threw in some dielectric grease packets for application to all my connections, again, recommended by Doug. Also ordered a 25' roll of +/- 18 AWG wire, some of which will be used for sure on the wiring of the fuel pump from the stock harness wires through the tunnel to the new front location.
Second package was from 70-914nut, i purchased his front turn signal lenses and gaskets from is car part out. I obviously opened that package as well so i could see how they look
Third new item to the garage..... I picked up the starter motor from Doug (mittelmotor), thanks again for that! Your 914 was f**king SWEET!!! that LS1 V8 looked (and sounded) amazing in there, and the sleeper status is off the charts, no one would ever see that coming! (2.0L badge, one of two exhaust pipes hidden, narrow body...) love it.
Next topic.... so since i have been stressed with all my school work i did some cleaning of the garage yesterday, i usually resort to cleaning when i need to blow off steam (either garage, room, or one of my fish tanks haha.) This time though i ran across one of the parts that was left in the trunk of my new roller when i got it, when i originally pulled it out i thought it was a rear sway bar, i then put it away for later use. I was moving it and then noticed that it was different than the rear sway bar i already had, and then it hit me, its a front under body sway bar, stoked. i was happy because my 71 doesn't have the holes drilled on the chassis for the thru body type, and the linkages i have for my thru body bar off my 72 are ovaled as sh*T. So since i dont need the adjustability or have the $$ for an aftermarket thru body (for now at least, next few years wont be racing, it isnt necessary at all) the underbody will be perfect! I asked Bruce today if he had any of the brackets/mounting tabs for that style bar, and sure enough he does! so i will pick those up from him this up coming saturday on my way to Dougs for more soda blasting.
If only it were this easy to fill up a few paragraphs with words when i was writing my advanced measurements lab report!
I love pictures, and even though i dont have much to show for this post, i still have some pictures! Talk to you all later
