Well to start with the good news, this engine is in the car!!!!
Was working on the car all of sunday, literally all day before i had to depart for SD to start my new job monday morning. Ill start at the beginning of the day:
As i showed earlier, the bolt/square nut to clamp the thermostar wire had stripped and need replacing. I had to do a makeshift replacement but it worked out well. Used a t-nut and cut a section off to create a flat area, and so it could fit in the tight spot period.
Next i installed the bdstone rebuilt pedal cluster. As you can see the right floor bolt isnt stock, the original one became rusted to the nut and sheared off upon removal. I drilled it out to just the right size to squeeze an M8 set screw in there; its nuted on the top and bottom. Clutch cable and accelerator cable are hooked up.
Next moved onto the shift rods. for the bushing shown below, I only had one, but realized i was supposed to have two... so i used an old oil cooler gasket on the other side; it fit nicely and seemed to accomplish the job. If this is a huge no-no, please dont be afraid to tell me. If this should get the job done for a bit, also please let me know!
Installed the clutch fork and throwout bearing, new cup bushing on the fork and vibration dampeners on the bearing.
cleaned up the starter motor
mated the tranny to the case, please keep in mind i was by myself the whole day, so this task deemed to be tricky, especially seeing that the case was on wheels and slightly kilter at a downward angle...i had to get inventive.
I still cant believe that this replaces all that was removed when using the tail shift components...looks so not upto par
lifted the engine into place, and checked location after every pump of the jack to make adjustments, once again i only had myself to double check everything was lining up
she's all in, the shift rod assemblies are in place and everything
As she sits for the next week until i go back for the weekend to attempt start-up!
I do have a few questions though!....
first, how do i transfer all the parts of the spedo angle drive from the tailshift to the sideshift...i couldnt get that unit out...?
Can someone please provide me with some good pictures of the two connection points of the sidesift rods, right behind the firewall at the rod coupling and at the stock (without that cover there obviously). I have all of it hooked up as of now, but it didnt feel right when trying to move around the shifter, and i think i forgot the friction ring bushing... so i will be redoing all that but would love some quality pics for reference.
Thanks everyone for all your help, dont think i would have gotten this far without your aid, but hang in there, i think the biggest challenge is coming up, STARTING it, and then tuning it!
