So i havent made too much progress the past week plus on the car since school has been keeping me occupied a lot, but as always, i have been collecting parts! A few items on the list that came in the mail/picked up at the swap meet:
engine rebuild gasket kit, tons of various bushings (susp and shifting), front bumper (for temporary use), rebuilt pedal cluster from Bruce, tilton master cylinder and hard line (for hydraulic clutch set up, will talk about in a latter post), platted pushrod tubes (thanks mark!!), 911 gague pod items (big clock, oil temp/oil pressure, fuel level/oil level), driver side mirror, PCA orange coast region sticker, and probably a few more things i am forgetting...
Had a wonderful time at Joe Sharps BBQ yesterday and the swap meet today. Was able to chat with a bunch of cool 914 guys this weekend, so that was really enjoyable (also got to see everyones sweet cars for inspiration)!!
I have an important topic i would like to start discussing, external oil cooler. I have never seen or heard of this being done, but i really want to mount it under the cowl fresh air openings, essentially taking the spot of the fresh air box and blower (which have been removed for good.) The cooler, which i will probably be getting from bruce, is a smaller one that i will have 3 92mm fans on the backside of sucking air through and blowing it into a custom air box that will lead into two "dump pipes," which i think i might plumb to go into the long heater tubes (this part is up in the air, but seams like it would be good solution, the holes in the fire wall are there...) The actual oil transportation hard lines will follow the path of the charcoal filter lines, the holes and grommets are already there waiting to be used!
This cooler will be on a partial flow system, leaving the stock cooler there and having the sandwich adapter to get the oil into the cooler. The fans will be operated by a switch in the cabin as opposed to thermostatically controlled.
Would LOVE to hear everyones opinons!!
I have modeled up the cowl, cooler, fans, and air box to see how much room they will be taking up. I have a total of just over 9" to work with from the bottom surface of the cowl to the bulkhead, and so far these parts will only take up 5" of that (keeping in mind though that the funnel into the two side exit tubes have not been modeled.....
Cheers
