QUOTE(falcor75 @ Jan 27 2020, 02:09 AM)
So I've been chasing oil leaks for a bit and itseems to be coming from this plug.
Click to view attachmentThe offending member weeps a bit of oil after sitting for a few days, I'm suspecting that it leaks more when being heatcycled.
I'd prefer to not pull it and reseal it, has anyone had any luck with some sort of exterior sealant?
That leaking plug appears to be steel. I think I see rust in the hex and lathe marks on the face. I can see the other two up at the oil filter area and by the one by the crank nose are aluminum.
Verify the leaking offender is steel with a magnet. These are NPT tapered pipe plugs. If steel, your are correct, it has probably loosened from heat cycling.
If steel you have 3 options:
1) Just tigten it. NPT pluts are an interference fit and tightening will stop the leak. Temporarily but probably for many years.
2) Pull the plug completely and use PTFE thread sealeant (liquid not tape) and reinstall.
3) Replace it with a properly installed aluminum plug.
If it's an aluminum NPT plug:
1) You'll have a very hard time getting it out without stripping the aluminum hex. Make sure you have a new tight fitting hex wrench before you even attempt this. Best bet is to gently heat the case (200F is plenty) and then cool the plug quickly by squirting water with a syringe right into the hex. Immediately try to loosen. This doens't work everytime. Sometimes the aluminum plugs have to be machined out but on the other hand if it is aluminum I'd be surprised that it is leaking in the 1st place.
2) If #1 fails, then you might go for the cover with JB Weld route but I absolutely hate this solution but in the past I've sucessfully used JBWeld to seal worse leaks in emergency situations.
3) If the hex strips, you're done. It will need to to be machined out. In your case #2 is likely the best solution unitl you need a rebuild or other case machine work.
Most importantly, don't mess with the blue aluminum plugs if they are not leaking. I prefer aluminum plugs. When they are installed properly, they don't leak and are basically a permanent fix when replacing galley plugs. DO NOT try to move or "re-seal" the blue aluminum plugs.We just had a relevant thread discussion on aluminum vs. steel oil galley plugs.
http://www.914world.com/bbs2/index.php?showtopic=342995Sorry wrong.
This plug is steel, but it's a factory plug there's no way it's NPT, it's a metric thread.
It's the machining hole for the oil pick-up. It won't leak running as it's suction from the oil pump, but it's likely leaking air into the pick-up circuit.
I've had it out before, worth a try at removing and reseal. If no joy clean and cover with JB, etc.
