QUOTE(cuddyk @ Mar 3 2018, 08:27 PM)
Yes. My tank and the steering rack are out so I had lots of room to work with, but it’s pretty straightforward. I released the clamps at the reservoir end so I could pull the supply lines down enough to easily cut right at the edge of the metal tubes. The short nipple on the Mc is to the back, and the worm clamp goes around the hose on that fitting, since it’s too close to the bulkhead to use a spring type clamp. The orange protective webbing goes on the rear hose as well. And you’ll need to trim both new hoses to fit, unless you can get them to pop up through the rubber grommets n the tank compartment floor.
Thanks
