Oct 22 2015, 08:29 PM
i'm in for at least 3
914-300Hemi
Oct 22 2015, 08:38 PM
Count me in for one.
euro911
Dec 3 2015, 01:35 AM
Mark, maybe you could cross-post this on the 912BBS too
mgp4591
Dec 3 2015, 02:35 AM
When will we learn more about this?
jacquot
Dec 3 2015, 10:05 AM
I'm in for one.
worn
Dec 3 2015, 10:57 AM
QUOTE(jacquot @ Dec 3 2015, 08:05 AM)
I'm in for one.
Count me in too for 1.
AndyB
Dec 3 2015, 11:47 AM
Price? Or did I miss that?
rfinegan
Dec 3 2015, 11:53 AM
+1 please
Amphicar770
Dec 3 2015, 12:18 PM
+1 for me
budk
Dec 3 2015, 01:54 PM
QUOTE(AndyB @ Dec 3 2015, 12:47 PM)
you missed it.... " NEW Group Buy 914 Master Cylinders $110 each" .... hidden in plain sight.
Mike D.
Dec 3 2015, 01:57 PM
I want 1 too, or 2 too, maybe.
80cap
Dec 3 2015, 02:18 PM
I also am in for one
mbseto
Dec 3 2015, 02:26 PM
I think there was another thread recently cautioning against getting a larger master cylinder with the stock calipers. IIRC, the problem was that braking becomes less progressive. My gut tells me 17mm to 19mm is probably OK, can someone share practical experience?
Dave_Darling
Dec 3 2015, 06:23 PM
When you install a larger master cylinder, you reduce your "hydraulic advantage" over the caliper pistons. It's almost exactly the same effect as moving the pivot point of the brake pedal.
The 19mm M/C has 25% more area to the piston than the 17mm one does. That means to get the same clamping force at the calipers, you have to exert 25% harder, though the pedal moves 25% less distance.
Most people seem to agree that the 19mm is a reasonable swap, but going up to 23mm (which I believe the earlier thread was talking about) is a Very Bad Idea unless you are significantly upgrading the caliper piston sizes.
--DD
mb911
Dec 3 2015, 07:21 PM
I would also be in for one
Mark Henry
Dec 3 2015, 08:14 PM
I'm in for one for sure...maybe put me down for two.
I don't think you'll have any trouble getting rid of the extra one if I don't take it.
7TPorsh
Dec 4 2015, 02:33 PM
I'd be in for a 17mm.
PotterPorsche
Dec 4 2015, 03:37 PM
I'm in for 1
Mark Henry
Dec 4 2015, 04:04 PM
QUOTE(7TPorsh @ Dec 4 2015, 03:33 PM)
If I get the jist Mikey (Mark) trying to put together the numbers for a fair size production run, so he's likely he's going to only be able to do the one size, 19mm.
19mm was likely chosen as it's the best size for a large enough production run to re-coop his investment from both the 914 and 911 crowd.
Likely he can't get the same per unit price on smaller runs for different sizes.
jcd914
Dec 4 2015, 04:17 PM
QUOTE(Mark Henry @ Dec 4 2015, 02:04 PM)
That is what he says back in post 38.
QUOTE(Mikey914 @ Oct 22 2015, 01:13 PM)
QUOTE(Mikey914 @ Oct 21 2015, 11:37 PM)
QUOTE(Porscheless @ Oct 21 2015, 09:59 PM)
I am in....Is there a larger(23? )mm option?Is this even necessary if i do a larger engine
Possible,
I'll be discussing with Eric tomorrow. Going to see how we can optimize the program.
Mark
Looks like we are best at
sticking with the 19mm for the time being. Yes we will be proceeding on these. May even make some improvements
7TPorsh
Dec 4 2015, 04:27 PM
QUOTE(Mikey914 @ Oct 22 2015, 05:12 PM)
QUOTE(BillC @ Oct 22 2015, 07:27 AM)
I'd like to get one, too.
However, if at all possible, I'd prefer to get one that is the correct stock size for my '73 1.7, since I'm planning to keep it all-stock. Any chance of doing a second GB at some point for the original size?
What is the original size, anyway? 17mm?
I'll get you covered, trust me
Guess I should have quoted. i assumed 17mm would be covered at some point. Can't you just sleeve the cylinder down to 17mm? I obviously have no clue.
"I would gladly pay you today for a 17mm on Tuesday."
Mikey914
Dec 4 2015, 10:29 PM
These will be 19mm.
Progress is that we are working on the tooling for the casting now. We have located a new ATE sample and are reverse engineering it. There are over 20 parts we will need to fabricate to make this we have 3 done at this point. Just like making a V2 rocket, but we will be doing some extensive testing on it to. It's being made with under our new manufacturing division. It will be a fully engineered part.
02loftsmoor
Dec 5 2015, 12:06 AM
QUOTE(Mikey914 @ Oct 21 2015, 05:22 PM)
I'm working on having new master cylinders made for the 914's. They are going to be 19mm to crossover for the 911 also. Now you can get a quality part at a reasonable price. These are about 90 days out, but they will be a quality product, that is fully engineered, not some junk imported from China.
Who's in?
I'm in
eric914
Dec 5 2015, 10:34 AM
+1
Bossman
Dec 5 2015, 10:54 AM
+2
restore2seater
Dec 5 2015, 11:00 AM
Add 1 to the list for me.
kid914
Dec 5 2015, 11:43 AM
me likes new parts...even more when they are improved....
in for 1...
TC 914-8
Dec 31 2015, 12:07 PM
Mark I'm in for 1 if they are still available ?!?!
Mikey914
Dec 31 2015, 02:56 PM
Actually not ready yet. SO no problem.
Mark
TC 914-8
Dec 31 2015, 06:42 PM
QUOTE(Dave_Darling @ Dec 3 2015, 04:23 PM)
--DD
Dave,
My car has the Brembo Boxster calipers up front, not sure if the MC was ever changed. My petal is still soft after many bleedings and purgings. You think a 19mm is a good choice? Or 23mm that came w boxters?
I have stocks w V kit in rear
Just curious
T
914bub
Jan 4 2016, 09:56 AM
Mark
Not to beat a dead horse,....but......any word on weather you might tap the reservoir hose holes for actual fittings? My MC is brand new and works well besides that,(it leaks). If you tap those I'm in, otherwise I can't really justify buying another. Any info would be great.
Thanks again for all you do for us!
danoswork
Jan 4 2016, 09:59 AM
QUOTE(Mikey914 @ Dec 31 2015, 12:56 PM)
Mark
interested in one, local, live in Tigard.
Cheers!
Mikey914
Jan 4 2016, 10:00 AM
We have a better solution for these that when available you more than likely will want. Unfortunately, since we are actually doing testing on these and the number of parts required to make these means we have to work on it one at a time. It will be awhile before these are available.
enikolayev
Jan 4 2016, 10:12 AM
Count me in for one as well.
Eugene
914bub
Jan 4 2016, 10:36 AM
QUOTE(Mikey914 @ Jan 4 2016, 08:00 AM)
We have a better solution for these .......
Could you give any more insight into improvements? If it's too early in the game I understand.
whitetwinturbo
Jan 4 2016, 11:57 AM
+1 please
maddin
Jan 4 2016, 03:41 PM
I'd have one too please!
02loftsmoor
Jan 4 2016, 03:58 PM
If I didn't put my name in the hat, I am now..
Wes
ctkellett
Jan 4 2016, 08:15 PM
I am in for one.
Dave_Darling
Jan 4 2016, 09:34 PM
QUOTE(TC 914-8 @ Dec 31 2015, 04:42 PM)
The Boxster MC will be boosted. Without a power assist, you may find that the 32mm one requires a large amount of leg to activate.
I don't know what the piston sizes in the Boxster calipers are like compared with the stock ones. It's good to keep near the stock ratio of total caliper piston area to master cylinder piston area, but I don't know the specific numbers for your case. But that should keep the pedal effort near stock.
--DD
pneuhyde
Jan 4 2016, 10:35 PM
I am in for one, too.
Steve
marksteinhilber
Jan 5 2016, 12:22 AM
I'll need one too. I'm reworking all brakes as I complete the five lug upgrade and refresh the suspension. Just over a year on the jack stands... Count me in.
mbseto
Jan 5 2016, 11:06 AM
I'm thinking I'll be in for one by the time they come out. Why so early in the process, is the GB more for gauging interest than economics?
marksteinhilber
Mar 11 2016, 01:02 PM
Mikey914
Mar 11 2016, 02:00 PM
Yes some progress, but there are many parts we have to make to get these done, I'd like to say they will be ready on X date, but it's a dart in the calendar at this point. I can say by end of summer (or before) I will have a needed related item.
RoadGlue
Mar 11 2016, 05:12 PM
Thanks for the update. I missed this the first time around. +1 for sure.
NeunEinVier
Mar 11 2016, 06:39 PM
QUOTE(Mikey914 @ Jan 4 2016, 10:00 AM)
Cool, video the testing while you're at it, no doubt everybody would like to see it.
SKL1
Mar 11 2016, 07:24 PM
Boy if these have some better arrangement for the supply lines I'd be in for 2. I absolutely HATE getting those damned lines to fit and get the rubber connections and washers in correctly, especially without removing the gas tank!!!!
Kansas 914
Mar 12 2016, 01:51 PM
QUOTE(Mikey914 @ Mar 11 2016, 01:00 PM)
Mikey914
Mar 12 2016, 07:55 PM
QUOTE(NeunEinVier @ Mar 11 2016, 04:39 PM)
We will be sending these parts out for independent testing. So maybe, I would expect these will be poles of documentation
