While I'm impatiently waiting on the front fender reconstruction and paint, I've been researching the many options and opinions on suspension setup.
My plan (subject to change) is to use:
- the original 19mm torsion bars in the donor '84 911 front end
- Koni 914 strut inserts KON-8641-1077 (I think they fit the 911 strut)
- Koni 914 rear shocks and spring set up from Ground Control
- no rear sway bar
- All new rubber bushings - most likely Elephant's
Remaining issues:
- What spring rate to use on the rear - 140?
- what front sway bar to use and what diameter - 21mm?
I'd appreciate any input to help finish the plan and purchase list.
Does this make sense?? What suggestion would you have for changes or for the spring rate and front sway bars??
Driving style will be "wannabe" racer, but actually mountain curves as fast as I can without wrecking or hurting my back on bumps.
I like big sway bars
They don’t make for a harsh ride on the highway
Yet give you a higher spring rate in the corners
My non flared street car runs a 21mm with 7 inch wheels
My non flared race car runs a 27mm. Also on 7 inch rims
The more wheel and track you have, the more leverage is impacting your spring rates So you need larger springs to maintain the effective rate
