southernmost914
Feb 11 2017, 04:09 PM
Mitox
Mar 2 2017, 08:54 PM
So, I've made some progress on the rotisserie. I've added a third leg and caster on each end, and removed the steel connecting the ends to each other. During March I need to make the mounting sections to connect to the 914 bumper locations, and get the car on the rotisserie.
I'd like to have the car as balanced as possible. Does anyone know the center of gravity vertically at the bumper mount locations?
Click to view attachmentClick to view attachment
speed metal army
Mar 2 2017, 11:00 PM
Mitox
Mar 3 2017, 11:10 AM
QUOTE(speed metal army @ Mar 3 2017, 12:00 AM)
Love the Lime Green. Love the wheels also; I plan to have mine done the same way.
Mitox
Apr 16 2017, 05:32 PM
I've made some progress in the rotisserie. I expect to have it complete this week; I just need to add the mounting points to the arms and finish the paint.
The next project on the list is to cut the front oil cooler outlet hole once I decide which methods of venting to use. I like the PMS kit, but I don't think the outlet vent has enough open area. I also like some of the project pics I have seen that have the outlets in the wheels wells.
After the venting holes are complete, I'll put the car on the rotisserie and start stripping the bottom. I'm thinking of using the Upol Raptor on the bottom.
ConeDodger
Apr 16 2017, 07:13 PM
The Moritz race car is Conda Green. I've seen a Conda Green car in person and that color is soooo fantastic!
t collins
Apr 16 2017, 07:38 PM
Keep up the good work neighbor
wndsrfr
Apr 16 2017, 07:43 PM
Here's Lime Green on Kermeee.....
Cracker
Apr 17 2017, 05:50 AM
Nice job on the rotisserie...I would be interested in "renting" it in the future if that is an possibility. My friend sold the car to Forbes (so he could in turn provide it to you). I believe we spoke awhile back as you were "determining a course" for this car - looks like it is gaining momentum. Good job!
Tony
Mitox
Apr 17 2017, 09:05 PM
QUOTE(southernmost914 @ Feb 11 2017, 06:09 PM)
OK, I admit it. I keep coming back to lust over the paint on your car.
Mitox
Apr 17 2017, 09:09 PM
QUOTE(Cracker @ Apr 17 2017, 07:50 AM)
Tony
Yes, thanks for spending some time with me going over the project. Now I can see the path to paint, so I hope I can move quickly.
Mitox
May 11 2017, 06:32 PM
Just gathered a few pieces over the past several weeks, and traveled to Hershey for the swap meet. I was somewhat disappointed with Hershey; seeing the cars was great, but the swap meet didn't match the hype. Maybe I expected too much. Anyway, the day after the meet, I purchased a Carrera front suspension in North Carolina.
The other parts collected include the center of the firewall, which I will use to make a cover for an access hole. I'm also awaiting shipment of a hook and grommet from one of the recent group buys.
Cracker
May 11 2017, 07:37 PM
Looking good...make big piles of parts!
T
Mitox
May 13 2017, 07:29 PM
Worked on the metamorphosing 914 most of the day today. Removing the rear suspension was easier than expected; three bolts and three nuts per side. I also removed the hood and rear trunk lid, so now to get it in the air for attaching it to the rotisserie.
I've decided to add an access panel on the firewall. The cover will be made from a section I purchased from 914 Ecology a few days ago. I've completed the rough trim on the cover; real happy with how it turned out.
Click to view attachment Click to view attachment
Mitox
May 13 2017, 07:36 PM
Can't decide whether or not to remove all of the old seem sealer in the trunk. I looks terrible, but its original. It may be interesting to keep the 41 year old fingerprint also.
raynekat
May 13 2017, 07:43 PM
That just the way the factory did the seam sealer back in the day. I wouldn't touch it if it's good shape. It will grow on you I think. When I re-seam seal parts of my car, I'll try to replicate this unique factory application.
Oh...and the car looks great. Have a wonderful time with the re-do.
Mitox
Jul 21 2017, 07:57 PM
I've finally been able to work on the GT again recently. I purchase an oil cooler from PMS and the shroud from QRS before starting the work to be sure I cut and weld in the correct locations. Here are a few pics of the progress.
Mitox
Jul 21 2017, 08:01 PM
Mitox
Jul 21 2017, 08:03 PM
Mitox
Jul 21 2017, 08:14 PM
Saturday's project is to finish fitting the braces shown in the pic below, and weld them in. I really liked what Armando did to his car as shown in his "Last New 914-6 GT Project" thread, so I'm using his ideas.
I'll also weld in sheet metal for the floor defining the outlet vent for the cooler.
Larmo63
Jul 21 2017, 09:16 PM
I'm doing all of these installs, actually I'm a bit ahead of you and done with them. I know what it takes to do this...
What you're doing looks great!!!!
defianty
Jul 22 2017, 07:57 AM
Good work, I was going to make my front trunk floor cut a different size to that but after seeing yours I think that's the way to go. Thanks.
Mitox
Jul 22 2017, 09:09 AM
QUOTE(defianty @ Jul 22 2017, 09:57 AM)
If I had access to a bead roller, the replacement sheet metal would have a wide channel bead in the middle to tie into small section remaining on the car.
Mitox
Jul 22 2017, 09:18 AM
I have a question for those more wise than I - everyone.
When I removed the floor section, the tow hook went with it. I think if I replace it closer to the front of the car it will be blocked by the front valance under the bumper, and the valance would be destroyed if I ever used the tow hook. What do you think?
An alternative would be to leave the tow hook off, and use bolt on hooks that mount to the front suspension mounts. Do these tow hooks work well? Tarett has one that looks good.
Any input is appreciated. Thanks
Mitox
Jul 22 2017, 09:21 AM
QUOTE(Larmo63 @ Jul 21 2017, 11:16 PM)
It's my first time doing anything like this, so I'm moving incredibly slow. Do you have any pics of yours?
Jul 22 2017, 11:01 AM
I'm a bit late to the party but for a period correct GT replica,
Conda Green (26G) is the only green way to go.
The Max&Moritz GTs were Conda Green and there is at least one car we know of (not a GT) that was delivered in Conda Green from the factory using the correct 26G paint tag instead of a 98 (Custom Color) tag. Even though Conda Green was never an official 914 color.
Larmo63
Jul 22 2017, 12:46 PM
Jul 22 2017, 02:03 PM
QUOTE(Mitox @ Jun 26 2016, 10:54 PM)
QUOTE(JRust @ Jun 26 2016, 10:46 PM)
Welcome & looks like your starting it right! What are you doing drivetrain wise
I found a 3.2 out of a wrecked '88 to slip in there.
Are you using the 915 trans
Mitox
Jul 22 2017, 05:00 PM
QUOTE(mepstein @ Jul 22 2017, 04:03 PM)
I want to use a 915, but I'll likely start out using the 901 and change it out later after it detonates.
Mitox
Jul 22 2017, 05:27 PM
QUOTE(SirAndy @ Jul 22 2017, 01:01 PM)
Conda is in the running still. I purchased a few custom mix spray bombs, so I can paint samples for comparison. I have three colors to try: conda green, viper green, and 2D8 green from 2007.
Mitox
Jul 22 2017, 05:29 PM
QUOTE(Larmo63 @ Jul 22 2017, 02:46 PM)
Very nice; and its green which makes it even better
Mitox
Aug 6 2017, 09:03 PM
I completed the front trunk floor welding last weekend and did some touch-up and grinding to smooth it out over the next few days. Still need to smooth the corners; waiting on Amazon to deliver a smaller roloc set.
I also filled in the four small holes in the floor. Why are they there anyway?
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachment
Mitox
Aug 6 2017, 09:09 PM
Here the almost finished shot. Needs minor smoothing. Not too bad I guess for the first time welding sheet metal.
The spare tire I purchased should arrive Tuesday, so need to figure out how to mount it vertically in the trunk wall this week.
Mitox
Aug 20 2017, 06:35 PM
I've been contemplating how to mount the spare tire for a while. I finally settled on a plan and completed the tire mount this weekend. I welded up the bracket shown below, and added a couple studs to the car to attach it to. Should work OK.
Mitox
Aug 20 2017, 06:36 PM
Spoke
Aug 20 2017, 06:46 PM
There's always Ravenna green as well.
Spoke
Aug 20 2017, 08:30 PM
BTW, great build. Good luck. Looking forward to seeing it completed.
Mitox
Aug 20 2017, 08:38 PM
QUOTE(Spoke @ Aug 20 2017, 10:30 PM)
Thanks,
hope to get it up on the rotisserie next month to strip the bottom
Mitox
Aug 27 2017, 07:13 PM
Didn't get to work on the project much this weekend. It's probably good though, because my welding was rather poor. It took a while, but I welded in the reinforcements today. I'll prime the area and weld the sections that I cut out earlier in the coming few days.
Mitox
Sep 3 2017, 07:07 PM
I've completed the reinforcements and welded the cut outs back; here's a few pics
Mitox
Sep 3 2017, 07:10 PM
Completed this section of the project, so tomorrow I'll start fitting the oil cooler shroud, and figuring out a way to mount the oil cooler.
totle
Sep 4 2017, 07:38 AM
Great work. In the same process with my conversion.
Did similar in the front for the oil cooler ducting.
Mitox
Sep 4 2017, 09:00 AM
Cleaniing the garage this morning, and need to make space. I'm thinking about trashing the old four lug wheels. I have all four.
Anyone need them? I'm in SW Virginia in Marion.
Mitox
Sep 8 2017, 08:55 PM
Getting close to finishing the oil cooler mod. Made a template this evening, so tomorrow it turns into steel with a few minor changes.
Mitox
Sep 20 2017, 09:06 PM
The bottom section of the oil cooler shroud is nearly complete now; it just needs minor touch ups for fit. I'll be working on the oil cooler mount next, or maybe I'll load the car onto the rotisserie and get the bottom stripped and coated before it gets cold.
Mitox
Sep 20 2017, 09:09 PM
Mitox
Sep 20 2017, 09:11 PM
Mitox
Sep 25 2017, 03:49 PM
WOW!! These pipes are beautiful.
I first noticed the welding quality; Ben is truly a master.
mb911
Sep 25 2017, 04:49 PM
Lots of practice
jd74914
Sep 25 2017, 06:32 PM
Your spare tire mount is awesome! Totally stealing that idea!
