So, I finished welding the seat belt mounting point and adjusting my home made part of the long:
Then time to start on the back part. Plenty of rust:
Inner suspension console has some rust, see here the holes:
Some bad repairs with metal over rust, and looks like the long's rust gets up to it :
So decision was made to remove it to repair correctly..and I opened again a can of rust..
So it's now removed:
But it is really rusted through on several places and poorly repaired on others..
I think I will order a new one instead of fixing it..will be cleaner, efficienter and easier!
Just for fun made some assembly :
Then it was time to remove the rusted long. My plan is to remove the rusted part of the inner long, weld the new one in (including engine mount and inner suspension console), and then remove the outer long with part of the wheel tray, and replace it. Even if everything is braced, I feel safer to make it one after the other to keep some sort of stability and measure points. Please tell me if anything speaks against it, I am still new in the 914world!
So here we are:
Time to remove the engine mount:
Rust behind it:
And out:
The long was really at the end of its life:
And now the parts ready for blasting:
And blasted:
The engine mount showed some issues :
So let's fix it:
Ready to weld:
One picture with a hint of the color, good for the motivation !
Now this topic is up to date!
Stay tuned,
Antoine
