Drex
Mar 14 2023, 06:33 PM
interesting method Jeff
i think i'll stick to the engine plate method tho
but to be extra safe,
i'm going to place wood blocks under the engine and tranny
while i loosen the engine and tranny bolts
just in case the floor jack would fail
then remove the blocks one by one as i lower the engine/tranny
according to this forum and the plate manufactures
the engine/tranny should be balanced on the lift plate
Drex
Drex
Mar 18 2023, 04:32 AM
received the two important tools i'll
need to drop the engine
plan to do this today or tomorrow
it is 10 F in iowa this morning!
Drex
930cabman
Mar 18 2023, 05:50 AM
Good day to recharge your battery and plan the attack
Drex
Mar 18 2023, 05:30 PM
Took out these 8 bolts
What is the best way to separate
the axles from the transmission?
Thanks
Drex
930cabman
Mar 19 2023, 07:45 AM
QUOTE(Drex @ Mar 18 2023, 05:30 PM)
Thanks
Drex
Give the hub a few gentle taps to seperate. There is a gasket in there, often the PO has applied some sealant in there making it "seal better". Remove the large (36mm) nut at the wheel side and remove the axle shaft.
Drex
Mar 19 2023, 12:30 PM
Engine is out of the parts car!!
Used a flat screwdriver with masking tape
and gently tapped around the CV/transmission joint
until it slowly split apart
Took a lot of patience
Had to use a grinding wheel on three of the four transmission mounting bolts
The top nuts were completely inaccessible
Also, the engine mounting bolts consisted of
recessed Allen bolts with a large nut on top
I was able to get a 17 mm socket on the top nut
and an Allen wrench, with a long extension, below
One came right off, the other broke the bolt off
If the Allen head would have stripped out
I'd would have had to cut the mounting bracket
Fortunately, this wasn't necessary
Drex
Drex
Mar 19 2023, 12:36 PM
The HELL HOLE
My plan is to completely strip this parts car
and see if anyone would want to buy the body
for sheetmetal
Drex
Drex
Mar 19 2023, 12:45 PM
Drex
Allen engine mounting bolts
Drex
Superhawk996
Mar 19 2023, 12:51 PM
So having done this - would you agree the Tangerine engine cradle is worth it? If answer is no, try putting it back in without. That might give an alternate view.
Hopefully you don’t regret it. I love mine and I’m just ashamed I didn’t invent it.
Drex
Mar 19 2023, 01:07 PM
Hello Superhawk!
Yes, I was glad I spent the $ for the tangerine engine lift plate
The tough part of dropping the engine were the mounting bolts
I was extremely nervous about safety
some used wood blocks under the engine
while removing the engine mounting bolts
But the plate worked like a charm and the
engine came right down
Drex
Drex
Mar 21 2023, 05:47 AM
The main WWII jeep site is
https://forums.g503.com/They have a Web site for pictures
to transfer into your threads
http://www.surfacezero.com/g503/index.phpDoes 914World have a similar web site?
Or which site do most of you use?
thanks
Drex
krazykonrad
Mar 21 2023, 07:33 PM
You can also upload photos straight from your photos folder. It is a little confusing, but if yo look just below the emojis, there is a "file attachments" button that will let you upload from the photos folder on your computer of phone.
Drex
Mar 22 2023, 04:46 AM
Hi Krazy
I tried to do this
but apparently there is not
enough file space
The photos are greater than the global limit
Drex
Drex
Mar 22 2023, 04:51 AM
When I loaded up the 914
Was in Stockport, IA
The Clark barn was featured in
the Iowa most beautiful Barn contest
Drex
Drex
Mar 26 2023, 08:36 AM
Am currently removing the pedal cluster from the parts 914
There appears to be 4 bolts holding the mounting bracket.
The back to bolts are straight forward
But how are the front two bolts attached to the frame?
Thanks
Drex
930cabman
Mar 26 2023, 08:57 AM
QUOTE(Drex @ Mar 26 2023, 08:36 AM)
Thanks
Drex
There are 2 nuts accessed from the underside also holding the master cylinder.
Do you have a Haynes or Clymer manual. very informative
Drex
Mar 26 2023, 09:52 AM
yes, i have both
there appears to be a very heavy plate
underneath the car that covers up access to these nuts
i have a 1973 Clymer manual
but could not find anywhere how to remove the pedal assb as a whole
Drex
Drex
Mar 26 2023, 10:08 AM
well...I think i figured it out...
remove the bottom access panel
this exposes the master brake cylinder
and think the bolts that hold it on
are the same two bolts that hold down
the front of the pedal assb mount
does this sound right?
thanks
Drex
930cabman
Mar 26 2023, 11:27 AM
QUOTE(Drex @ Mar 26 2023, 10:08 AM)
thanks
Drex
Exactly, and you saw the plate is lightweight 18 or 20 gauge like everywhere. I first thought this access panel was a skid plate.
Drex
Mar 26 2023, 12:51 PM
This was just left of the glove box on the panel
What was it used for?
Drex
930cabman
Mar 26 2023, 01:54 PM
1975 Ford Pinto, rear door
Drex
Mar 26 2023, 03:32 PM
whoo...
i'm not following you?
Drex
FlacaProductions
Mar 26 2023, 03:34 PM
QUOTE(Drex @ Mar 26 2023, 11:51 AM)
Drex
Glovebox lock.
I think you would be well served to get a Haynes manual.
Drex
Mar 26 2023, 05:09 PM
That makes sense
I have a lot of pictures of 1971 interiors
and none of them had this lock
I also tried to search for 'dash lock'
and could not find a specific answer
I did get hits on a few threads
but they were double digits long
I almost have the parts car disassembled
so will see about getting the 'better' 914 running
....I'll try not to ask dumb questions
Drex
930cabman
Mar 26 2023, 05:44 PM
All of us were beginner's at some point and there are no dumb questions, the members here have been very helpful to me and will continue to assist as we are able. What decent parts are salvageable from the parts car?
krazykonrad
Mar 27 2023, 11:05 AM
Here are the parts manual from Porsche:
Porsche 914 PETHere is the service manual:
Porsche 914 Service Manuals
Drex
Mar 29 2023, 03:02 PM
Pretty much done topside
so pulled parts car outside with my bobcat
flipped it over and pushed it back into the garage
Does anyone see anything, other than the rims,
that would be salvageable?
Am about ready to take the remaining body to the dump
Thanks
Drex
Jamie
Mar 29 2023, 03:24 PM
QUOTE(Drex @ Mar 29 2023, 01:02 PM)
Thanks
Drex
Those appear to be original steel wheels that might have some service left if they are in salvageable condition.
Dion
Mar 29 2023, 03:28 PM
Trailing arms, steering rack out? Some might need them.
rick 918-S
Mar 29 2023, 04:55 PM
Brake Caliper cores
seanpaulmc
Mar 29 2023, 05:26 PM
Frunk floor.
Drex
Mar 29 2023, 06:55 PM
The rear trunk floor pan was pretty rusty on the rear edges
I don't think it can be saved
The car is just about ready to break in half!!
I have a lot of parts I have taken off.
Do I dare post a picture of them on this thread
or would this inappropriate?
Thanks
Drex
SKL1
Mar 29 2023, 08:54 PM
Mention the parts Dave, and then list them on the classified section.
Boy, there is NO snow left is there?
Assume that car lived it's life in Iowa and paid the price!
friethmiller
Mar 30 2023, 01:19 PM
Can you make sure to add your parts car to the VIN database? Alive or dead, we track them here.
http://www.914world.com/bbs2/index.php?act=membervins
Drex
Mar 30 2023, 04:28 PM
Will do
Haven't located the engine number yet
Drex
seanpaulmc
Mar 30 2023, 06:35 PM
QUOTE(Drex @ Mar 29 2023, 08:55 PM)
Thanks
Drex
Rear trunks typically see rust from water damage.
Posts #75 and #127 show, from here, that the floor of the front trunk, also called “frunk”, looks to be in one piece. Many are chopped up from having A/C systems installed or lumpy from floor jack usage. The metal may not be perfect but looks salvageable, again from this perspective. New is available but if this one is going to the scrap yard someone here
may be able to use it.
I might have another piece in mind if you are going to cut it up. LMK.
Regards,
Sean
rick 918-S
Mar 31 2023, 05:59 AM
Sent you a PM. Glad you found that parts car.
krazykonrad
Mar 31 2023, 10:41 AM
QUOTE(Drex @ Mar 30 2023, 02:28 PM)
Will do
Drex
Mar 31 2023, 06:55 PM
Is this where the SN is supposed to located?
Is it there but I can't see it?
I think I saw somewhere
where it is located on the flat where the spark plugs are
Drex
JeffBowlsby
Mar 31 2023, 09:02 PM
Did you pull the main chassis harness out and did it come out in one piece?
Drex
Apr 1 2023, 05:21 AM
I have not saved the harness yet
Are they worth saving?
Also, here is the rear trunk floor
Look good enough to save?
The trailing arms look awful rusty
Is this just appearance and would
they sand blast and powder coat ok?
Finally, I'm having a heck of a time
getting to, and removing the rear
brake calipers
thanks
Drex
JeffBowlsby
Apr 1 2023, 08:19 AM
If the harness wiring is not cut or hardened it can be reused. Even if it has a few cut wires it can be repaired. If you remove, no need to cut anything especially where pulling it through the engine bay firewall, that cut destroys the harness. You will need to just remove the plastic connector housings at the relay board 14 pin connector, fuel pump connector and headlight connectors. Pretty simple, just compress the wire terminal tangs and pull the terminals out of the housings.
You have a 71 - which version of the chassis harness do you have early or late? The difference is best seen at the steering column connector - is it 12 pin or 14 pin?
Drex
Apr 1 2023, 02:31 PM
On parts car:
window SN is 41712915293
front door jam is 2899508
paint code is L 60 E (so Irish Green)
rear door jam is 07/71 4712915293 very hard to read (I suspect it is the same as the window SN)
engine number not found yet
Drex
SKL1
Apr 1 2023, 02:34 PM
Unless they're bent the rear trailing arms would probably clean up ok with blasting etc. With new bushings and bearing I'd bet they would be usable.
Drex
Apr 1 2023, 03:28 PM
Jeff, is this the pin connector your talking about
I only count 13 pins
Drex
JeffBowlsby
Apr 1 2023, 06:52 PM
Thanks Drex! You have the late-1971 chassis harness, lucky you! The connector is a 14 pin connector but it correctly has only 13 pins. Willl PM you.
krazykonrad
Apr 2 2023, 10:43 AM
QUOTE(Drex @ Mar 31 2023, 04:55 PM)
Drex
The engine number should be just in front of the oil fill "tower." Its on the flat, horizontal lip at the front of the "tower's" base.
Montreal914
Apr 2 2023, 10:50 AM
Maybe:
- Muffler heat shield that we see in your upside down picture if in salvageable state.
- Center section of the firewall might be useful to someone with a six conversion to make an access panel.
Edit:
I know I could use this fender bracket
Drex
Apr 3 2023, 06:51 PM
Removed the complete harness today
It's a little beat up in areas
but mostly intact
Pushed a lot of wires thru tiny holes!!
Drex
Drex
Apr 6 2023, 10:42 AM
Well...
The remaining carcass of my parts 914
Went to the dump today
400 lbs
Ready to start in on the real project
Drex
