Drex
Jun 16 2023, 07:43 PM
yes, probably
i remember when i was restoring my '63 (actually a '62) VW beatle in the early 2000's
i had subscribed to a couple of VW magazines then
i drained the oil today
no metal or other debris
really looks pretty clean after 40 years
i also boroscoped cylinder # 4
i need to practice at it
and will post some pictures when better
thanks
D Rex
bbrock
Jun 17 2023, 06:59 PM
QUOTE(Drex @ Jun 9 2023, 04:34 PM)
i'm just curious as most of my vehicles are old
and do not have this feature.
i've braked hard only on rare occasions
even locking the brakes up, but without serious consequences
on my newer vehicles
it seems when i need to brake hard
which is also rare
i would never get stopped fast enough
to avoid an accident
it seems like a paradox to me
Drex
I say this only to get under
@Superhawk996 's skin, but the brake regulator was an early ABS system
You might also be interested to read what Eric Shea (the 914 brake expert) has to say about the regulator and whether you need it:
https://pmbperformance.com/products/porsche...vin-47429-15752
wonkipop
Jun 17 2023, 07:30 PM
QUOTE(bbrock @ Jun 17 2023, 06:59 PM)
which is also rare
Drex
https://pmbperformance.com/products/porsche...vin-47429-15752as was the anti-dive factory front suspension settings.
Superhawk996
Jun 17 2023, 09:02 PM
QUOTE(bbrock @ Jun 17 2023, 08:59 PM)
which is also rare
Drex
https://pmbperformance.com/products/porsche...vin-47429-15752 @bbrock
Drex
Jun 18 2023, 06:42 AM
this is # 2 cylinder
i used DW-40 to spark plug overnight
as it was very tight
what do you all think?
thanks
D Rex
Drex
Jun 18 2023, 06:45 AM
# 4 cylinder
again spark plug with WD-40 overnight
so the fluid in cylinder is the leftover WD that
dripped into the cylinder when i removed the plug
D Rex
Superhawk996
Jun 18 2023, 09:35 AM
You can start and run engine but it is unlikely to be 100%
Boxer engines don’t store well being prone to condensation and rust pitting in the bottom of the cylinders.
Set aside funds for the eventual rebuild
930cabman
Jun 18 2023, 09:53 AM
QUOTE(Superhawk996 @ Jun 18 2023, 09:35 AM)
It's a coin toss, she may or may not run decent. But a rebuild is in order at some point. Is the rest of the hulk somewhat road worthy? You just might get some seat time this season
Drex
Jun 18 2023, 10:22 AM
think i need to check and make sure there are no nests
under the engine tin or between the cylinders
if there is...i'll drop the engine and clean everything up
is it possible to remove the engine tin with engine in car?
probably will just fill all the cylinders with WD-40
and let them sit for several weeks
then suck out all the remaining debris
all this while
fixing the 'Hell Hole'
installing the new SS fuel lines
new brakes and line
etc.
seat time this season?
have my doubts
D Rex
Superhawk996
Jun 18 2023, 10:30 AM
QUOTE(Drex @ Jun 18 2023, 12:22 PM)
D Rex
Excellent plan - would be well served to ensure oil cooler isn’t gunked up. If it were me I’d put new oil cooler seals in while tin is off and engine is out.
Might as well do the crank seals
And then the pushrod tube seals
Doh
And that’s how the madness goes before you know it you might as well build a freshie
I admire the restraint
Drex
Jun 30 2023, 06:44 PM
here is a picture of how the throttle cable attaches to the plenum
en route to the throttle body
just two nuts on either side of a slot in the plenum
tho i was trying to avoid it
i've decided to drop the engine to facilitate:
hell hole repair
new battery mount installation
SS fuel line installation
and to inspect, clean, and replace parts on the engine
will need to repaint the hell hole
where is a good source for the L63K willow green paint?
(is there a way to create the umlaut u on these posts?)
is this willow green a different color than the 43 paint
for the 914-6 and the later models of the 914?
thanks
D Rex
930cabman
Jul 1 2023, 05:30 AM
Good call to drop the engine, it will make everything much easier. As far as I know the original paint was synthol enamel, currently NLA. There is some acrylic enamel around, but I am unsure of matching Willow green
rick 918-S
Jul 1 2023, 06:09 AM
Is the engine lid paint finish in good condition? Take to your locate auto body supply store with the paint code info from the car. They can research the code and mix a pint. Then check it against the lid. Likely single stage urethane now.
Drex
Jul 20 2023, 12:41 PM
No
I did not fall off the earth
My daughter is getting married in two days
So been working on this project
But...
Engine is out
Now for that hell hole work
Drex
930cabman
Jul 20 2023, 01:18 PM
Congratulations on your upcoming wedding
now, hell hole is another story
SKL1
Jul 20 2023, 08:49 PM
As noted, congrats on the wedding.
And go enjoy that Corvette too! Assume you still have the WW2 jeep???
Drex
Jul 23 2023, 05:25 PM
yep
holding off on the 1941 willys
to do this 914
D Rex
Drex
Jul 28 2023, 10:35 AM
Saw this car on 'Rockford Files'
The episode is 'The Countess'
Looking for a way to raise up the engine and transmission together
Any ideas?
Where are the attach points if I use an engine lift?
D Rex
JeffBowlsby
Jul 28 2023, 11:34 AM
QUOTE(Drex @ Jul 28 2023, 09:35 AM)
Any ideas?
D Rex
I use a couple of threaded rods at the front engine bar ends and lift the trans end with a floor jack. Its a slow but safe method.
Drex
Jul 28 2023, 12:07 PM
would you happen to have a pic of this set up?
i'd be nice to set it up on some kind of rotisserie
to work at any position
thanks
d
JeffBowlsby
Jul 28 2023, 12:25 PM
QUOTE(Drex @ Jul 28 2023, 11:07 AM)
thanks
d
I dont have a photo of this, but I had understood that the question was how to raise the engine/trans assembly as one unit into the car. Are you wanting to mount it to an engine stand?
Geezer914
Jul 28 2023, 01:40 PM
Remove the trans, clutch and flywheel. Bolt the yoke on the motor and call your strong neighbor over to lift the engine and slide the yoke into the stand.
Drex
Jul 29 2023, 12:12 PM
I was thinking about putting
the entire engine/tranny
on some sort of rotisserie
This would enable me to
clean up everything with ease
Has anyone ever attempted this?
Or is this just a plain crazy idea?
D rex
krazykonrad
Jul 29 2023, 06:22 PM
The correct yoke on an engine stand should let you rotate the engine 360 degrees. I've never seen the transmission bolted to the engine on a stand. I would have some concerns about the torque it would put on the engine stand bolts.
By itself, the transmission is pretty maneuverable by hand.
Konrad
Drex
Jul 30 2023, 07:26 AM
i don't plan to tear engine apart
just want to clean it up
assemble it on a rotisserie
trial start it
and then reinstall in car
i'd have another engine stand
on the transmission end
D Rex
930cabman
Jul 30 2023, 07:33 AM
I would set up the assembly on a sturdy bench to test/run the engine. I have never seen a rotisserie for the engine/trans assembly. Have you seen/heard the engine running?
Drex
Jul 30 2023, 03:11 PM
yes
our accountant brought it to our office
a few times
then the crash in Des Moines, IA
and sat ever since
so, it ran well at that time
i'm confident it will again
it only has 60k miles on it
D Rex
930cabman
Jul 30 2023, 04:56 PM
QUOTE(Drex @ Jul 30 2023, 03:11 PM)
yes
a few times
and sat ever since
D Rex
How many years ago was "the crash"
I would pull the spark plugs and get a compression reading of each cylinder first. Often times either an exhaust or intake valve has been open for a time with resulting oxidation on the valve, seat or cylinder wall.
Vette is running well?
Drex
Jul 31 2023, 02:21 PM
here is a typical view of the valves
crash was in 1974
car sat in an old barn during that time
i suppose at the least
i should pull the heads
and have the valves redone
new pistons and rings
thot i could just run it for awhile
and the valves would seat alright
probably wishful thinking
wife and i take a cruise in the vette
almost every night
D Rex
930cabman
Jul 31 2023, 02:56 PM
She has sat for 1/2 century, her butt must be quite sore to say the least
It may run, but may not. what do you have to lose
To tear the engine down and do a complete rebuild is best, but .........
Is your intention to get some seat time this year?
How bad is the hell hole?
Do the doors open and close properly?
Drex
Aug 3 2023, 08:28 AM
hell hole is rusty with a few holes
but very bottom is solid
of course the battery tray will have to be replaced
D Rex
krazykonrad
Aug 4 2023, 01:00 PM
Actually, that's not bad at all. Check the suspension ear underneath to be sure.
930cabman
Aug 4 2023, 01:23 PM
She's been parked since 1974
rjames
Aug 4 2023, 01:41 PM
Wirewheel the brown away and see what's left. Doesn't look too bad from here.
930cabman
Aug 4 2023, 04:27 PM
QUOTE(rjames @ Aug 4 2023, 01:41 PM)
Or Ospho
rjames
Aug 4 2023, 11:16 PM
QUOTE(930cabman @ Aug 4 2023, 03:27 PM)
Or Ospho
Just putting Ospho on the rust isn’t going to tell you if there’s solid metal underneath. Given how easy it is to access the area, there’s no reason to not do it right.
wonkipop
Aug 5 2023, 12:38 AM
QUOTE(Drex @ Aug 3 2023, 08:28 AM)
D Rex
gee they rusted fast didnt they. i mean thats 4 years worth.
but it still looks ok. pretty straightforward to pull her back from the brink.
go for it. great little car. fab color.
Drex
Aug 5 2023, 09:27 AM
where is the suspension ear?
i'll wire brush the hell hole down and re-post picture
thanks
D Rex
MikeK
Aug 5 2023, 09:41 AM
QUOTE(Drex @ Jul 20 2023, 12:41 PM)
Do you know what brand of exhaust you have? I have the same setup on mine.
Neat project. Cool color.
Drex
Aug 5 2023, 11:28 AM
i don't know muffler brand
or if it is even original
still need to match the paint color
to re-paint the hell hole when repaired
D Rex
930cabman
Aug 5 2023, 03:07 PM
QUOTE(Drex @ Aug 5 2023, 11:28 AM)
D Rex
I am restoring a '75 Palma Green example, original Cali car with minimal rusting. There was some hell hole work I completed and when done I used a brush on oil based enamel available from True Value. The color is reasonably close to Palma and actually still looking for Palma in single stage acrylic enamel.
Any progress with the engine? or too busy cruising in the vette
Drex
Aug 6 2023, 02:22 PM
between my daughter getting married (7/22)
and my partner gone all last week,
i've been too busy and tired to do much the last couple of weeks.
i have most of this coming week off and plan to work on 914 then.
hell hole work 1st (hopefully no surprises)
then new jack support plates welded in
then will turn to the engine
on FI engines
besides new hoses
what are the essential new parts i will need to purchase?
plan new
coil, distributor cap n rotor, oil cooler seals, air intake collars
fuel pump, etc
do i need a new
MPS, fuel pressure regulator and what else?
thanks
D Rex
JeffBowlsby
Aug 6 2023, 02:50 PM
QUOTE(Drex @ Aug 6 2023, 01:22 PM)
on FI engines
besides new hoses
plan new
fuel pump, etc
do i need a new
thanks
D Rex
Dave, you may need some of the FI parts, or none of them, other than gaskets, hoses and filters. It fully depends on the condition and completeness of what you have to start with. The great thing about D-jet is that each component can be tested individually, and the tests are not hard if you understand how each item functions.
Here is an excellent resource for the correct parts needed:
https://members.rennlist.com/pbanders/Your main concerns should probably focus on confirming a functional ECU, MPS, TPS, TS2, the trigger points, fuel pump, relay board, and the engine bay harnesses - FI, Ignition, and Alternator, as well as fuel injectors including the fifth injector (CSV).
Lay out what parts you have, post photos, and lets see where to go from here.
Your FI system is one of the simplest on a 914 ,it should look like this:
Drex
Aug 6 2023, 04:01 PM
thanks Jeff
lots of material to digest
will dive in
Dave
krazykonrad
Aug 6 2023, 05:52 PM
Drex
Aug 7 2023, 12:08 PM
thanks Krazy!
i'll check it out.
D Rex
SKL1
Aug 8 2023, 09:59 AM
You mean Steve gets time off??????
Drex
Aug 8 2023, 10:46 AM
Steve is my partner
he's been gone for the last 8 days to California
Will be working on 914 tomorrow
D Rex
Drex
Aug 10 2023, 10:00 AM
here is the area below the hell hole
also, today i took a piece of metal into
our local body shop to see if they can match the willow green paint
D Rex
SKL1
Aug 10 2023, 07:39 PM
Doesn't look that bad from that angle but what does it look like at the jack receiver and longitudinal opposite to that?
