Got to take a break last weekend and make a run out to the G&R 914 Swap meet in Riverside. Was able to meet up with my son. Got to drive his Targa. Also picked up a couple of rear trunk lids from Bruce - thanks.
You might be thinking - what do you need two for? Well to do the mods planned (see first pic) I need to cut the ribbing along the front, and I'm cutting two small openings for the NACA ducts, and a big chuck out to clear the intake tube. That will get a new piece, but I want to reinforce the underside with the same ribbing - so one trunk is for the finished lid, the other is for the ribbing. Plus I have my original white lid for ribbing also.
I lucked out and Bruce had one that already had the duck-tail spoiler - which I was thinking about adding. Unfortunately it's got a slight tweak to it - but I thought I can fix that - so bought it with that in mind. It's in pretty good shape & I like the smooth transition from the spoiler into the lid.
Click to view attachmentFrom the on-end view you can see how the right side (left in photo) doesn't curve as much as the left, and so its raised up slightly.
Click to view attachmentOn the underside, you can see the bent rib. I'm thinking I can make a wood form of the correct curvature & use that to re-bend the lid into shape. If it doesn't work, I can use this lid for its ribbing, and use the other lid for my final one. I'll just have to add the spoiler myself.
Click to view attachmentThis one still needs some minor work, you can see there's some cracking under the paint. They probably used just bondo, instead of something with a little more strength.
Click to view attachmentClick to view attachmentAlso decided to up the height of my rotisserie stands by 7.5 inches. This will enable me to move the car right from the dolly onto the rotisserie and back onto the dolly without having to do a lot of jacking. I just have to raise the adjustable pads on the dolly to their max, connect the rotisserie, then lower the pads & slide the dolly out. Now I just have to get over to Tucson to buy the steel.
