OK, first of the year is over, got caught up on all vehicle maintenance, now I can get back on the teener.
Spent this last weekend on the soda blasting. I've decided the larger outer panels will get paint removed with flapper discs. But the trunks, engine bay, etc, will get soda blasted. It's ideal for all those irregular shapes, little corners, etc.
Before I could do any blasting I had to build a ramp that I could roll the rotisserie out on. Gravel just doesn't cut it. Had lots of scrap left from the car lift crate so it's not going to waste.
Click to view attachmentThe blasting progressed a little slow until I got things dialed in properly. Had Friday afternoon to work on that. Love the look of the clean metal. Using a tarp under the car and plastic sheets surrounding the work area I was able to reuse almost 75% of the material.
Click to view attachmentThen was able to spend most of Saturday working on the engine bay and under the trunk. Cleanup after soda blasting is a big job, but it's well worth the time saved. Sunday started to get humid and rained in the afternoon, so didn't get much done then.
Click to view attachmentDecided to remove the muffler heat shield. I wanted to drill the welds from inside the trunk but was unable to locate them accurately. Decided to do them from the shield side. I've got nuts I'll weld to little stop plates that will go behind the drilled mounting brackets. They get flood welded then a single hole drilled for a hex bolt.
