Recently, I've been fixing and updating things that have bothered me since I did this conversion years ago.
1. Install one of McMark's Master Cylinder brace. I've always had a sort of soft brake pedal, so I was hoping to get a firmer pedal removing any possible flex.
Click to view attachment2. Discovered the right front wheel had a bit of wheel bearing slop which in turn was opening the pad on the passenger caliper. Adjusted the nut properly, clearance all the calipers, and bled brakes. The pedal is hard as a rock now...
Click to view attachment3. The 1 1/4 water line that comes out of the "typical" Renegade water setup requires a sharp 90 degree turn to properly follow the floor of the car to the radiator up front. This would cause the hose to kink, even though once the system pressurized the hose would fill out...it always bothered me. I installed an aluminum 90 degree tube to replace the area of the hose that would kink.
Click to view attachmentClick to view attachment4. Four over 3 years my Renegade dual fan setup worked flawlessly. Both fans were setup to come on at once at full speed. Wanting to reduce the noise of the fans, I rewired them according to the diagram below that utilizes 3 relays to create a multi speed circuit.
Thanks to the 914 community for discovering that one of the relays I was sold was incorrect (two 87s, instead of an 87 and a 87a) which really through me for a loop.
Here is what I started with.
Click to view attachmentSchematic for using 3 relays and how it works...
QUOTE(904svo @ Feb 5 2014, 08:46 PM)
C1 grounded
Here's the current path, C1 gets ground operates relay #1 , #30 supply's bat to pin 87 which is wired to one side of the fan motor #2 the other side of the motor is
wired to #30 on relay #3 which is not operated and flows current to #87a which
is wired to the other fan motor the other side of this fan motor is grounded. Both
fan motors are in series now ( each motor has 6 volts to them).
C2 grounded ( note C1 not grounded)
Relays 2,3 operated, Relay' #2 supplys 12v #30 to #87 which is wired to motor#1
the other side of the motor is wired to grounded ( fan #1 has 12 volts Full speed)
relay #3 #30 is wired to fan motor #2 the other side is wired to relay #1 #87
motor #1 will not operate till C1 is grounded.
So what you have is a 3 speed operation if the fan motor can run on 6 volts
C1 grounded both motors have 6 volts on them
C2 grounded Motor #1 fullgrounded
C1 and C2 gounded motor #1 and #2 full speed
Click to view attachmentInside look
Click to view attachmentA lot of wires...
Click to view attachmentClick to view attachmentElectrical box
Click to view attachmentDone. I can't believe how quiet the fans are now at 1/2 speed. I've been very fortunate to have a cooling system that works awesome and can get away most of the time on the slower fan speeds.
Sensor 1 triggers at 180 degrees both fans at 1/2 speed
Sensor 2 triggers at 200 degrees at full speed on both fans
