QUOTE(stewteral @ Nov 11 2008, 07:39 PM)
Hey Computer Skids:
I'll offer the answers I can. I started my 914-V8 with Renegade and found that Scottie & crew don't know what they are doing, are NOT car-guys and turn out CRAP from their shop. I have met Scottie and chatted twice and know him to be a USED CAR SALESMAN. Did you know in 2002, there was guy in LA who ran a site for a year just to show the bad work that Renegade did..and he was a specialty car sales shop who had planned on buying 15 Renegade cars.
YES, I am dumping on Renegade, but only to keep you from getting MORE screwed than you are from buying their kit. I really hate dishonest people.
I built my car completely myself and not a SINGLE Renegade part in it! I have a built 383 (500 HP) + 930 trans + 12" x 1.25" Wilwood rotor & 4-piston calipers.
I also welded in a complete rollcage which is a great investment for safety and stiffening the chassis!
"However, this is an area of my BIGGEST disagreement with sloppy Renegade: what happens when you drag the bottom of the car over a bad driveway?
I installed 1-1/2" copper tubing and soldered bends on their path UP the central tunnel, up and under the gas tank into the front trunk..there is room and it wasn't hard to do! You could also run 1-1/2" rubber hose and get it done faster. This approach takes cutting access in the engine-bay firewall and then holes through to the trunk. To get access, I cut open the top of the tunnel (and cleaned out 30 years of rust and gunk) and replaced it with Alu sheet.
BTW: I am using a Mezier Remote Electric water pump which was cheaper than the Renegade mechanical thing. The advantage is that when you are idling in traffic, the electric is pumping at max rate! Constant optimal cooling!"
stewteral@verizon.net
There's one in every crowd
Maybe he wasn't held enough as a child?
I've lost track of how many V8 conversions I've owned, but I have four right now. Needless to say I've seen the good, the bad, and the ugly.
I've probably bought 10 or so conversions that were already done. Two cars were actually built in house at Renegade before I worked there. Of those 10 cars that were already converted, only the two that were converted at Renegade could be driven reliably without ANY additional work.
The first 914 was converted by Renegade in 1990 then in 2006 it had a tall ratio 915 installed and had a few updates. No problems at all. It might as well have been a honda.
The other Renegade in house car I bought was a 911. Basically someone had bought it already converted and it went to Renegade for inspection. Virtually everything had to be redone. Shortly after Renegade finished it the guy needed money for a pending adoption, and I got a nice car at a great price.
When the car was originally brought to Renegade it ended up on the "Wall of shame". For those who don't know, the "Wall of shame" is reserved for conversions that went wrong. That car is actually still on Renegade's website in that section. Ultimately Renegade replaced the front pan, upgraded the cooling, fuel tank, engine, and conversion components. The end result was a very fast car that ran great. I was very happy with the work that Renegade did, and again, that was before I worked there.
Even though the Renegade small block chevy kit has been around for 20 years it has undergone improvements along the way. It currently incorporates the same floating radiator design that the LS1 kit uses, although the flow characteristics are different. The kit is easy to install, well made, and most importantly it just works. The quality of the machined components is world class.
If you're the type of guy that would rather "build everything yourself" you can do that. Some guy built a remarkable Lamborghini replica in his basement. Of course it took him 10 years and he could have just bought a real countach, but he did it on his own terms. If they are properly installed the kits are in no way sloppy or poorly engineered. One real problem is that often a conversion will be represented as a "Renegade conversion" when it actually only has a Renegade adapter plate that's 20 years old. Everything else might be cobbled together.
Every in house car that Renegade builds is done to the customer's specifications. Some guys just want a basic driver that's safe and reliable while others want something show worthy. Most people fall somewhere in the middle. So, as a consequence, some cars are going to be nicer than others. Plenty of jobs get turned down because the scope of work needed exceeds what the customer can either justify of afford. Right now there's a 1997 993 twin turbo getting upgraded to an LS3 and a 1991 928 getting a 640hp LS7, so there’s plenty of high end work going on.
Suggesting that everyone should run their cooling lines inside the center tunnel leaves me scratching my head. First and foremost, that is really invasive, especially for a kit customer. Secondly, your fuel lines run in the center tunnel and putting them in a confined space with 180 degree coolant is a bad idea. Not to mention how much more heat will migrate into the cabin.
I'll be the first to say running the coolant hoses on the underside of the car isn't the most elegant solution, but it works great, it's easy to do, and it's inexpensive. The underside of a 914 has two recesses along the center tunnel that guides the hose and provides 1/2" more ground clearance. If it's done properly it really doesn't look bad. In terms of function, it's a very direct route that minimizes restriction and most importantly it doesn't trap air.
I know of only one person who had an issue with hoses under the car. He didn't see a VERY large speedbump and nearly high-centered his car. It bent one of the hose retainers over and restricted the flow. He reached under the car, bent it back, and went on his way. Regardless of whether you have hoses under the car or not, you're going to look under the car when you hit something like that. Gates green stripe is extremely tuff stuff. Anything that would get through it would probably compromise a copper or aluminum solid line as well. Of course you can't do a quick roadside repair on a solid line.
Unless there’s a back-story behind the animosity, I just don’t get it. The first time I visited Renegade five years ago I was very impressed with the quality and attention to detail. They used almost all new hardware, even on the transmission covers. I’m not saying Renegade is perfect, like any business they are only as good as the guys doing the work. Several previous employees are members of 914world, and I know for a fact they are very competent mechanics and fabricators.
Everyone here loves what they do, even the office manager drives a 914 every day. You won't find many places with more "car guys" (and gals) than Renegade.
Rather than stir something up why don’t you post some pics and details of your car so everyone can admire your work?
