Well, I installed my rebuilt 901 with the re-geared 5th "h" gear today...and low and behold it worked beautifully. No grinding, smooth shifting, and no funny noises! I even had left over parts...LOL, then of course one of my 901s became the bone yard for many...which was cool.
I can't believe how many rpm I carved off with the new h gear--somewhere around 500-700 at 65. I like to go to the Central Coast which is a 3 hour drive. That means my engine will have turned almost 100,000 less times in one trip. Thats' got to be a big plus in the gas mileage department. I was getting 20mpg, it will be interesting to see the mileage now. With 305 lbs of torque to the rear wheels there is no lag between 4th and 5th...perfect.
Dr. Evil thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you!
