I got quite a bit done today. Put my rear window back in (did it a while ago & pulled it as I just didn't get it quite right). Put all trim pieces back on.
Installed the center console, backpad & seats
Center cushion (thanks Morph) .
Installed inner door seals (thanks Mikey914) Have the outer door seals to do
Installed door threshold plates (Thanks Dave)
Its been so long I couldn't find some parts. Luckily I have my 73 here to swipe pieces/hardware from.
I've got my door panels all ready to go but need to get endcaps & the triangle window seal from Mikey914. So those will go on along with the door panels.
I will have a delay installing my engine. Just not happy with the battery tray install or the area around it. I'm going to pull it off & redo it. I'm also going to replace the seal channel below the batter tray. It had some rust & has some little chunks missing. I'm going to get that all cleaned up as it just pisses me off
That area should have been taken care of by my paint guy. At least it will be done right.
Overall it was a kick ass day. It was beautiful & sunny. I spent the day in & out of the garage between 914's
