Cough is good news. What kind of mechanic did you bring your car to? You gave him a good 2ltr for his work...I'm sorry for sounding a bit put out, but a year later???
Test the voltage at the fuel pump harness before you connect another pump. Also make sure the relay is good and the fuse hasn't been rigged. It's hard to believe you had 2-3 bad pumps, but hey who knows. Might want to just hot wire the next pump for now and see if you can get your motor running.
Yeah the cough is good news. I actually checked more fuel pumps before putting them in. Went through more like 5 but all had issues with leakage. I'm pretty sure this is the dead one. I should be able to get the working one from him this week. I will check the voltage from the harness too. What should it be putting out voltage wise with the key on?
As far as feeling put out . It's my own fault. I should have picked it up a long time ago. Guy had some serious personal & health issues come up. Still doesn't quite cover why it would take so long. So while I will never take a 914 back there. I also am not going to bash his business publicly. I certainly won't be sending any of my friends to see him either. Having said all that. He is a nice guy & I wouldn't avoid him if I saw him.
