Series9
Jun 2 2011, 02:03 PM
QUOTE(ellisor3 @ Jun 2 2011, 03:32 PM)
QUOTE(Madswede @ Jun 2 2011, 02:45 PM)
Rawk!
Now I wanna hear it.
Me Too. Kick Ass Joe.
It sounds very serious. It's low and grumbly.
I just went to start it again and it wouldn't. The fuel pump seized. It's brand new.
Compared to the rest of it, this is nothing. I'll return it. Whatever.
Madswede
Jun 2 2011, 04:21 PM
I like the advice you gave me a long time ago: Hit it with a hammer.
(I know, the 3.2 isn't a low-P pump for a carburetor set up, but hey at this point ...)
tomeric914
Jun 2 2011, 07:24 PM
QUOTE(Series9 @ Jun 2 2011, 04:03 PM)
That's luck. Better it seized now than after you delivered it.
Series9
Jun 9 2011, 04:38 PM
Working through the list.
I pulled the fuel pump and cleaned it out. I think a little debris stopped it from running. It's working now
The TPS is finished.
I found the wiring problem that was not allowing the engine to be turned off with the key. I was getting 4 volts across the alternator light (field) that was just enough to keep the ECU power relay closed. I moved the gauge power to another switched terminal and that fixed it.
I fabbed the DFU brackets today:
Eric_Shea
Jun 9 2011, 06:28 PM
Looking good Joe
Series9
Jun 10 2011, 04:42 PM
So I'm hooking up the drive shafts and I find this (anyone see something wrong?):
Series9
Jun 10 2011, 04:43 PM
There's no way to get that axle out without:
Series9
Jun 10 2011, 04:45 PM
/4 muffler hanger modified for this job.
I also finished the MAP sensor manifold adapter, but it's not exciting enough to warrant a picture.
Eric_Shea
Jun 10 2011, 05:47 PM
Missing pins or is it a 6-bolt?
Series9
Jun 10 2011, 08:48 PM
QUOTE(Eric_Shea @ Jun 10 2011, 07:47 PM)
6-bolt w 4-bolt boot so you wouldn't notice if it were installed.
Eric_Shea
Jun 10 2011, 09:50 PM
Probably common I'm afraid. 930 (6-bolt) 108mm CV's are the only 108's available right now...
Either pin that one with larger (12mm?) pins or drill the bosses on the flange and stub axled to accept the 10x1.5 fastener (my choice). Be careful though, both pieces are hardened and it will cost you or your machinist a "bit" or two. If you pin it you'll still have to widen the holes in the stub and flange.
Series9
Jun 11 2011, 06:41 AM
QUOTE(Eric_Shea @ Jun 10 2011, 11:50 PM)
I found a new Lobro 914 CV on eBay. It's on the way.
ellisor3
Jun 11 2011, 09:42 AM
Eric or Joe,
Could you explain in a little more detail what the issue is, I am not sure I understand what I am looking at.
Series9
Jun 11 2011, 03:54 PM
QUOTE(ellisor3 @ Jun 11 2011, 11:42 AM)
Eric or Joe,
914 CVs have four bolts and two pins. This one is a six-bolt CV, so it's not possible to pin them. Your 3.2 would break that arrangement. I have the correct one on the way.
I got some more done at the end of the day when I was finished with Byron's 951.
Adel clamp fun. I'm very happy with the oil lines attached to the lower valve cover. They were a bitch to install, but all is very secure and nothing will be rubbing.
I also spent some time getting started on tidying up the wiring in the engine bay:
Eric_Shea
Jun 11 2011, 10:18 PM
You're using 914 CVs in there?
Series9
Jun 23 2011, 03:01 PM
Many little things are being accomplished randomly, but today I made the intake with the MAT sensor installation and I made HUGE progress in the tuning of the engine.
If I had the last pieces it would be very drivable. I should be able to run it around the block next week!
My eyes are friggin' burning from the exhaust fumes.
We are very close to completion.
Here are pictures of the intake fab, finished intake and tuning workstation:
racerbvd
Jun 23 2011, 03:35 PM
sweet, if you are going to be around tomorrow, I may sneak down to drop off the 951 seats, anything else you need me to drop else off??
ellisor3
Jun 23 2011, 08:15 PM
Joe, I know you had some reservations about the Tec GT system. What are your thoughts, good and bad?? When can we see some #'s
Series9
Jun 23 2011, 08:31 PM
I didn't and don't have reservations about the product. I had reservations about the amount of money and time it would cost to set up and tune on a stock engine, when we could use a stock Motronic DME that would make it run perfectly right out of the box.
The ignition portion of the system is excellent. At this point, distributors should be obsolete. Now you get to enjoy a virtually maintenance-free ignition.
As for the fuel side, it should be drivable now. I'll have to put some miles on it and tweak it some more. The file that was sent to me for this engine was basically unusable. It would neither reliably start nor accelerate the engine off idle. On the up side, this has caused me to have to dig deeply into programming and work it out on my own.
Also, if you decide to modify the engine in the future, I will be able to adapt the engine management to accept the changes. In that way, it could pay you back some of what you've spent.
The cool-factor is high. You're going to like it.
I'm gonna
next week. I'll take some video for you.
Series9
Jun 24 2011, 11:00 AM
I'm not really working on James' car today, but I like to start it at different times of the day to see how I'm doing on the programming for different situations, hot, cold and otherwise.
This morning, it stumbled, but didn't start.
Then I noticed the TPS voltage (on the screen on the laptop) was 0.00.
That's wrong.
Hmmmm. What's this?
Teething pains:
racerbvd
Jun 24 2011, 10:09 PM
Can't make it tomorrow, the Pod didn't show up, so the guys drying out my house couldn't load it so the Plumber could strt working on my slab leak..
So I need to make it Wed or after, correct, and if I need to bring anything for that car, let me know..
Series9
Jun 28 2011, 02:39 PM
Lots of stuff got crossed off the list today.
No pictures, but the interior is back in, the shifter is installed and working, the INTERIOR LIGHT is wired and functional, the oxygen sensor wiring and module were permanently installed, the new CV is in and I proceeded with some more tuning with the lap top.
Unfortunately, I'm still waiting on one more piece before I can run it around the block.
It's getting very close.
racerbvd
Jun 28 2011, 03:05 PM
QUOTE(Series9 @ Jun 28 2011, 12:39 PM)
What are you missing?? Depending on the weather, I'll be down tomorror or Thurs, to pick up the Turbo "S", still dealling with plumbing issues from the slab leak & water damage..
Series9
Jun 29 2011, 03:07 PM
Today was the last day of fabrication. I'll be getting the last part on Friday. I'll drive it that afternoon.
Here are the bottom cooler brackets and fan/O2 sensor wiring:
ellisor3
Jun 29 2011, 06:29 PM
Alright!! Let's drive it
Series9
Jun 29 2011, 07:58 PM
QUOTE(ellisor3 @ Jun 29 2011, 08:29 PM)
Friday........
racerbvd
Jun 30 2011, 04:50 PM
Good seeing you today Joe and thanks for Lunch....
Series9
Jun 30 2011, 08:02 PM
QUOTE(racerbvd @ Jun 30 2011, 06:50 PM)
I'm already looking forward to the JAX visit next month. Everyone, stand by for pics......
Series9
Jul 1 2011, 11:46 AM
I drove it!!
It's fast.
Video is coming once I figure out how to make it smaller.
racerbvd
Jul 1 2011, 11:58 AM
QUOTE(Series9 @ Jul 1 2011, 09:46 AM)
I drove it!!
It's fast.
But does it stop???
Rand
Jul 1 2011, 12:08 PM
QUOTE(Series9 @ Jul 1 2011, 10:46 AM)
I drove it!!
It's fast.
Nice work Joe. Congrats ellisor3, you must be stoked about now.
Bee Jay
Jul 1 2011, 12:47 PM
I drove it!!
It's fast.
Music to my ears. I hope to use those exact words in about a month.
Congratulations.
Bee Jay
ellisor3
Jul 1 2011, 12:56 PM
QUOTE(Series9 @ Jul 1 2011, 01:46 PM)
I drove it!!
It's fast.
Kick ass Joe. Fast, well that sounds----Fast. Let's go get a ticket!!!
Series9
Jul 1 2011, 06:13 PM
I'm working on the video. It's 195 MB for three minutes.
Stand by.......
Series9
Jul 1 2011, 06:22 PM
I was waiting on the throttle linkage from Rich.
It came today. When I started to install it, I noticed that something was wrong.
It looks like this tranny has an intermediate plate from a REAL 6.
I screwed the bellcrank shaft into the transmission and modified the RJ bracket to do the rest:
Series9
Jul 1 2011, 06:23 PM
I had to remake the cross-over oil line between the coolers because the 45 on the passenger side was in the way of the throttle linkage.
Series9
Jul 1 2011, 06:35 PM
Series9
Jul 1 2011, 06:39 PM
Click on the picture.....
0396
Jul 1 2011, 06:44 PM
wow:)
ellisor3
Jul 1 2011, 06:49 PM
That is awesome Joe. I have already made out my check to the Tax Collectors Office, I will fill in the blank when I actually get the ticket. I will have them set me up a tab.
Series9
Jul 1 2011, 06:50 PM
QUOTE(ellisor3 @ Jul 1 2011, 08:49 PM)
You better make out a few checks. It's effin' fast.
Series9
Jul 1 2011, 07:12 PM
James,
It runs great, but it's too rich. Basically, the programming will continue on a line that supports an incremental reduction in fuel delivery.
I doubt you want 12 MPG.
Just wait. It'll be perfect.....
Series9
Jul 2 2011, 06:50 PM
Today, I put down the video camera and took the car for a real drive.
I don't know if it's just the muffler's sound making me think this thing is faster than a normal 3.2, or if it really is.
Either way, it's very quick.
On a slightly negative note, we have a substantial oil leak from somewhere around the breather outlet on top of the engine. It could be one of the O rings in the oil thermostat or a bad seal in the idiot light switch. I'm going to have to clean the area up and figure out where it's coming from. At least it's not one of the cam towers....
I also have yet to see a working tachometer. I've tried two different units that should work with the signal this computer outputs, but no dice.
I'll be back on it on Wednesday.
Elliot Cannon
Jul 2 2011, 07:12 PM
QUOTE(Series9 @ Jul 2 2011, 05:50 PM)
I had a nasty leak in my 3.2 a few years ago. My worst fear was a leak in the cam tower. It turned out to be the oil pressure switch. An easy fix. I was told it is not unusual for that switch to leak.
tomeric914
Jul 2 2011, 08:54 PM
QUOTE(Series9 @ Jul 2 2011, 08:50 PM)
Gaaahhh, yeah I was just there...
http://www.914world.com/bbs2/index.php?s=&...t&p=1500608
Series9
Jul 6 2011, 07:53 PM
I think I found the leak.
When the engine arrived at S9, I noticed the crankcase vent was put on backwards.
I removed the four nuts, turned it around and bolted it back up. What I didn't notice was that the gasket isn't symmetrical, so it should have been turned around too.
Long story short, it's a bitch to get to with the engine in the car and the FI installed, but I fixed it.
James, that one's on me.
Now I need to clean up all the oil and hope we don't see much more. Trying to get a six to be completely drip-free can be a tall order, but I don't think we should need a beach towel to clean up the oil under the car after each drive.
racerbvd
Jul 9 2011, 04:40 PM
James, head up to Whitey's tonight, I'm getting ready to head down, after the long day I have had, I can use it..
Yea, about Sexy....
racerbvd
Yea, about Sexy....
KELTY360
Jul 9 2011, 05:17 PM
QUOTE(racerbvd @ Jul 9 2011, 03:40 PM)
Yea, about Sexy....
Click to view attachmentReally hope there's no leak from the crankcase vent.
Series9
Jul 9 2011, 05:19 PM
I had some major break-throughs on the programming today. Over the past few days, I've done a huge amount of reading. Today, I started data logging with each programming change I made.
The engine runs out to redline in under full load and I'm getting good O2 sensor readings almost across the board. There are a few tweaks to be made, but I think I'm very close.
I think I've got this one by the nuts.
I'm trying to become a recommended tuner for Clewitt Engineering, so when I think it's finished, I have to submit the data file for approval. Hopefully that will go well.
I'm planning delivery by August 1st.
