Jan 12 2011, 08:31 PM
QUOTE(timofly @ Jan 12 2011, 08:33 PM)
QUOTE(mepstein @ Mar 21 2010, 07:45 PM)
QUOTE(jmill @ Mar 21 2010, 08:34 PM)
QUOTE(kwales @ Mar 20 2010, 05:45 PM)
That may be an aftermarket sway bar. I have a huge diameter rear sway bar that was made by Addco and it's bolted onto the trunk floor of one of my cars- just like that.
A photo of the mounting link area where it attaches to the shock area might show which it is. The factory uses a ball stud to attach to the shock, and Addco uses a bracket. I have one of each of the rear sway bars.
The factory 2.0 swaybar had a doubler spot welded above the mounts inside the rear trunk. No doublers means it's not a factory 2.0 car. Being an early tub ruled that out anyhow.
Did the vin on the top of the inner fender get ground off and painted over?
I want to get rid of the rear swaybar anyway.
Seems like the vin is from a 74?
Anyway, not so important since I'm not trying to sell car. and since everything matches, it shouldn't be a problem re-registering car. If there was something fishy done- once upon a time - well, that was 25+ years ago.
Scott - Remember, that foglight switch has a secret function
Mark, that is a '74 VIN, about 17 numbers away from mine!
17 numbers and 4 years away.
Where are you in NJ? I know there are a bunch of 914's around but I never see them.
Jan 14 2011, 11:11 AM
So far it's been pretty easy. Powdercoated parts will get bead blasted, injectors will get overhauled.
Jan 14 2011, 11:23 AM
Cracked fan housing will be replaced.
scotty b
Jan 14 2011, 12:23 PM
Mark if that stuff is really powder coated, blasting won't do jack to it. You are going to need to get s gallon of aircraft stripper and soak the pieces in it for at least a few hours, possibly overnight depending on how good a job was done.
Jan 14 2011, 12:40 PM
Yes, you told me that's how you do it. I was going to leave the parts natural and wipe down with this product - Gibbs Brand www.roadsters.com/gibbs
RiqueMar
Jan 14 2011, 12:45 PM
It'll make them look really sharp if, once they're down to their base, you sand them to get everything smooth. I was going to do the same thing with the 3.2 we have, as you can see the lines where they come together...
Jan 23 2011, 07:41 AM
Ferrari 308 cores
Jan 23 2011, 07:45 AM
+ Eric Shea's magic
Jan 23 2011, 07:46 AM
= 914-6 GT calipers
Eric_Shea
Jan 23 2011, 12:04 PM
happy to be a part of this build.
tomeric914
Jan 27 2011, 08:47 AM
Might be worth clear coating those pretty calipers. Cad plating alone doesn't last long especially if you plan on driving it regularly. Certain car wash concentrates and wheel cleaners will degrade cad plating.
Eric_Shea
Jan 27 2011, 08:54 AM
ATE uses Zinc so do we.
tomeric914
Jan 27 2011, 09:11 AM
QUOTE(Eric_Shea @ Jan 27 2011, 09:54 AM)
Yea, but the same thing can happen with zinc.
Eric_Shea
Jan 27 2011, 09:13 AM
Clear peels and discolors so... you're kinda stuck either way.
tomeric914
Jan 27 2011, 10:18 AM
True. Your work is a thing of beauty. Just trying to prolong it!
BTW, I had intentions of just rebuilding/rejetting the carbs I bought from you but you made everything look too nice. Now I have to clean everything else up as well!
Eric_Shea
Jan 27 2011, 10:34 AM
(sorry)
That should be a nice 914 setup. Try the Pinesol trick?? Looks like others here have had good results.
tomeric914
Jan 27 2011, 03:20 PM
QUOTE(Eric_Shea @ Jan 27 2011, 11:34 AM)
(sorry)
Sorry for the threadjack Mark.
I haven't cleaned them yet. Had to make sure they came apart first. Typical corrosion inside from sitting. One air corrector was munged and had to be CAREFULLY drilled out to the point of picking the brass threads out of the carburetor body threads. Jets and rebuilds on order. Should get to it next week.
scotty b
Mar 26 2011, 08:08 AM
THE AMAZING FLYING EPSTEIN !!!!
jimkelly
Mar 26 2011, 08:15 AM
or your rotisserie section not tied in to each other?
one day, my pig is gonna be there getting the full spa treatment, one day.
jim
scotty b
Mar 26 2011, 08:19 AM
Not tied together. I don't see any need if the other bracing on the car is done properly. I also am not finished with the rotisserie. I still need to add some hydraulic jacks on either end to raise and lower it, add some casters to move it around, and if I feel it need it I will add a tie in. Once the wheels are on I think I will need the tie in. Also going to remake the mounts. These were temporary to get the last job done and to get back on Marks car.
Mar 26 2011, 09:26 AM
Would it look funny to delete the windshield washer jets? The pressure system was never functional in the past and I never plan to spray water at this car on purpose.
scotty b
Mar 26 2011, 11:24 AM
QUOTE(mepstein @ Mar 26 2011, 07:26 AM)
So you're never going to wash it ?
hot_shoe914
Mar 26 2011, 11:31 AM
QUOTE(scotty b @ Mar 26 2011, 12:24 PM)
Nope, he plans to have it shined down at the corner dry cleaners. I just hope they don't over starch it!
Mar 31 2011, 05:48 AM
Did a shop day at Scott's. Made some progress on the engine parts.
jimkelly
Mar 31 2011, 06:00 AM
are these all sand blasted - or is this the finish?
Dr Evil
Mar 31 2011, 06:10 AM
QUOTE(mepstein @ Mar 31 2011, 07:48 AM)
Did a shop day at Scott's shop. Made some progress on the engine parts.
Poor Scotty
EdwardBlume
Mar 31 2011, 06:14 AM
Mar 31 2011, 07:00 AM
QUOTE(jimkelly @ Mar 31 2011, 08:00 AM)
Heavy duty paint remover, wire wheel, glass bead blasted and then sprayed with Gibbs to (hopefully) prevent oxidation.
Scott was right - removing powder coat is a bitch!
Mar 31 2011, 07:01 AM
QUOTE(Dr Evil @ Mar 31 2011, 08:10 AM)
Poor Scotty
I ran the blaster all afternoon and spoiled his peace and quiet.
SUNAB914
Mar 31 2011, 07:52 AM
I still need to make it down there, sorry only an hour away and can't get off my butt to do it. Soon I hope! Are you open on Saturdays?
scotty b
Mar 31 2011, 08:39 AM
QUOTE(SUNAB914 @ Mar 31 2011, 05:52 AM)
for now. As the weather gets nicer I will be here less and less on Saturdays.....I hope..........
Apr 7 2011, 01:15 PM
Trying to clean engine of remaining colorful tin. PO powder coated tin yellow. Removes easy on the top but I would have to remove (destroy) oil return tubes on the bottom to remove tin. Replacements are $25/each but the thought of doing anything to a leak free engine makes me cringe. I want tin to be silver or black. Any suggestions?
Not my engine but good example of what I'm talking about.
type47
Apr 7 2011, 02:43 PM
QUOTE(mepstein @ Apr 7 2011, 11:15 AM)
Any suggestions?
Forget about the bottom of the engine. It'll be hidden behind the headers and if you are under there seeing it, you've got bigger troubles.
tomeric914
Apr 7 2011, 03:13 PM
QUOTE(mepstein @ Apr 7 2011, 03:15 PM)
Any suggestions?
Lower the ride height so nobody can look underneath.
Apr 7 2011, 03:22 PM
Good points but I've looked at too many engine pics on Pelican and Bee Jay had to show how clean and neat his turned out, and blah blah blah.
So maybe clean and scuff the yellow powder coat and then paint with high temp coating.
Have to see what Scott will approve.
scotty b
Apr 7 2011, 07:39 PM
Apr 7 2011, 07:49 PM
Yea, starting at post #1
okieflyr
Apr 8 2011, 11:28 AM
QUOTE(type47 @ Apr 7 2011, 04:43 PM)
Any suggestions?
Let the yellow tin be your health or leak indicators ....
May 12 2011, 03:59 PM
Well, it's not quite ready for assembly but I couldn't resist doing a quick mock up.
Still need to send out fuel injectors, convert oil cooler and buy DME(EFI brain) and harness.
May 12 2011, 04:02 PM
Our resident German girl stands guard.
jim912928
May 12 2011, 04:33 PM
yellow will make it faster! lol
MDG
May 12 2011, 04:37 PM
The engine is looking great, Mark! Did you end up using the Vertex fan shroud and if so how was the fit?
m.
May 12 2011, 04:52 PM
QUOTE(MDG @ May 12 2011, 06:37 PM)
m.
Yes. I bought the shroud direct from Vertex. Ordered over phone to make sure I got the right one. Great customer service and fast shipping. Alternator and fan fit perfectly. They said they have tweeked the mold and this one is 3rd generation. Comes in the gray as pictured. Doesn't have the smooth finish of stock shroud and looks a bit more industrial than oe Porsche part. Does match the bead blasted finish of my other parts. Says "Made in SA".
J P Stein
May 12 2011, 07:17 PM
The oil return tubes on the motor pictured are of the collapsible type....ether it is not a good example or you have no problem removing them without damage.
May 12 2011, 07:36 PM
QUOTE(J P Stein @ May 12 2011, 09:17 PM)
Your right, not a good example. I'm over that now. Too many other things going on.
Loser_Cruiser
May 12 2011, 07:54 PM
What was your reasoning for using the 3.2 intake on your 3.6? I have heard of people doing this, I was just hoping I could hear the justification.
May 12 2011, 08:08 PM
QUOTE(Loser_Cruiser @ May 12 2011, 09:54 PM)
It's a 3.2 engine. I'll be lucky to get it back together and not have spare parts like Greg in Brady Bunch.
scotty b
May 12 2011, 08:15 PM
QUOTE(mepstein @ May 12 2011, 06:08 PM)
That may very well be the first and only time the Brady Bunch has been mentioned on this site
Eric_Shea
May 12 2011, 10:01 PM
Can you believe Greg was hit'n that?
Cairo94507
May 13 2011, 07:05 AM
But I WANT a 3.2!
