scotty b
Jan 15 2013, 09:22 AM
BIGKAT_83
Jan 15 2013, 11:30 AM
Here you go.works like a champ. The fuel pressure is set by the regulator on the fuel rail of the SVX.
Click to view attachmentBob
scotty b
Jan 15 2013, 12:59 PM
awesome. Thanks Bob.
I've been looking at SVX fuel pumps and senders, and they just don't lend themselves to a good adaptation, as they screwed onto a plastic tank. The Impreza one does since it bolts down
Chris H.
Jan 15 2013, 02:46 PM
Yeah and that plastic screw-top is a PITA to get off...
Bob, didn't you use the Impreza top with the SVX pump?
BIGKAT_83
Jan 15 2013, 02:57 PM
No I just ran it the way I got it out of the Impreza. Didnt even change the pump.
All I needed to do was cut a hole in the tank for it. The pump goes right into the stock tank sump. I used rivet nuts to bolt the plate in.
Bob
Chris H.
Jan 15 2013, 03:01 PM
Ahhhhhh.... I misunderstood you. That's normal for me though.
I thought your setup looked weird compared to mine. I guess I sell the SVX pump then! Thanks again for the guidance.
DBCooper
Jul 15 2013, 03:53 PM
QUOTE(scotty b @ Jan 15 2013, 08:22 AM)
Ha ha ha ha! Boy Scotty, when you're right you don't let it go, do you! Ha ha ha. Good one.
jimkelly
Jul 23 2013, 10:20 AM
CptTripps
Oct 17 2013, 09:38 AM
Can we update some of the data in this thread? There are a lot of new projects in the works, and many have found better ways to do some of the things outlined here.
...just sayin'.
1stworks
Mar 7 2014, 11:31 AM
great info!!!!!!
Thank you
76-914
Mar 7 2014, 03:40 PM
Hmmmmmm, mine is an EZ30D, not the EG33.
mgp4591
Mar 7 2014, 03:57 PM
QUOTE(76-914 @ Mar 7 2014, 02:40 PM)
But didn't you start off with an EG33 then move to the EZ30? And why, maybe besides the weight and size?
76-914
Mar 7 2014, 04:20 PM
Initially I thought I would go the EG route but the length and improvements on the EZ model turned me. BIGKAT83 started w/ a 3.3 then went w/ a 3.0. BTW, the EZ's are only 1.5" longer than the 4's.
mgp4591
Mar 7 2014, 04:27 PM
QUOTE(76-914 @ Mar 7 2014, 03:20 PM)
I know the size is a big improvement and thus the weight also, but when I picked up a running SVX with 109k for only 1500 bucks it made sense to stick with that. It fits altho it will be a bit tight, it weighs a bit more but still acceptable and the parts options are deep with it only being 2 more cylinders than the 2.2. The basic engine is bulletproof like a 2.2, but the sound of a flat-plane crank is rather exotic and it's gonna haul ass...
badmiata
Mar 9 2014, 08:22 PM
I saw this on 818 forums. Its very expensive $350+, but it is pretty sweet looking. Its being used for WRX trans I assume it would work for us in a 914. Planned on adding a photo but i cant?? its called a K Tuned No Cut K Swap Shifter Box K20 K24 Swap EF EG EK DC2 for a honda and the photo is on thefactoryfiveforum.com/showthread.php?13606-RoRi-s-818S-Build-Thread
charliew
Jun 22 2016, 11:45 AM
well I'm still lurking and watching all the new ideas and thought I would get this back to the top for updates guys. I got sidetracked for awhile with pacemakers. I wish pacemaker tuners were as good as opensource or megasquirt or stinger guys but they aren't and only will get better as the users get more educated. I still want my 914 to roll with all my goodies completed one day. My son has decided he wants a new awd project so I may be on my own with the subie 4 cyl stuff. His sti was dynowed a couple of years ago at about 490 awd hp on e85 on a 98* day in dallas after a 90 mile drive. I have lots of time in his setup on fabbing but he is the tuner mechanic and he has decided he is tired of working on a street hotrod. It is hard to get to almost anything on that awd gocart. I wanted to buy it and just put it in the shop for him when he is my age (71) but he is 34 and doesn't see the greatness of that idea. Oh how I wish I had my first hotrod still. Sorry for the rant, This is a great resource that needs updates or at least new thread links.
76-914
Jun 22 2016, 12:20 PM
Where the Hell have you been, Charlie? Good to see you back in the stable and looking forward to your posts. How have to locals accepted the SS presence? I used to deliver "take out dinners" to those boy's when they watched over LBJ's daughter in Austin. IIRC, they had absolutely no sense of humor.
charliew
Jun 25 2016, 12:21 PM
I forget to ask my friends who go to the same church but the ss must blend in well. Also the anoited ones might be up north consoling the younger one with their dad.
Optimusglen
Feb 3 2018, 02:14 AM
Any info on putting the radiator in the engine compartment?
76-914
Feb 3 2018, 09:57 AM
Go to the Restoration & Build Threads Forums section. A lot of us have detailed it in our build threads.
charliew
Feb 4 2018, 02:02 PM
QUOTE(Optimusglen @ Feb 3 2018, 02:14 AM)
not enough airflow in the engine compartment for a 2-500hp motor radiator. that was done many years ago with a stock non turbo na suby google is your friend
Feb 4 2018, 02:47 PM
QUOTE(mgp4591 @ Mar 7 2014, 05:27 PM)
I paid $500 for one with 180K but I figured once I get the conversion running, I could always buy a 2nd engine to play with. $200 for an mt5 trans with axles and starter. $550 to have the wire harness converted. I paid my local mechanic $100 to pull the engine and then once I pulled the main harness in his lot, he got rid of the car. Best $100 i've ever spent. Amerson is going to install the running gear and fab a front radiator but even if I had a smaller engine, it would get a front rad. It just makes sense to put it out in the fresh moving air vs dead hot air in the engine compartment.
r_towle
Feb 4 2018, 05:08 PM
QUOTE(mepstein @ Feb 4 2018, 03:47 PM)
You paid $550.00 to have a wiring harness converted to mate a 914?
Feb 4 2018, 05:22 PM
QUOTE(r_towle @ Feb 4 2018, 06:08 PM)
Yes. Worth every penny.
r_towle
Feb 4 2018, 06:18 PM
QUOTE(mepstein @ Feb 4 2018, 06:22 PM)
Sounds like a business opportunity.
Feb 4 2018, 06:56 PM
QUOTE(r_towle @ Feb 4 2018, 07:18 PM)
It is for the guy who did it for me.
He mostly does vanagon conversions.
It takes a lot of time.
He made it to fit the 914.
I know my limits and wiring far exceeds them.
