Here's the shift rod mod.
I took a different approach to what's been done here by some.
I just rotated the rod without the set screws and noted the amount of rotation to clear the header.
I cut the rod ends with a sawsall and ground the ends clean.
Tacked the rod together and tested it.
Made slight adjustments and welded it up, grind, clean and paint. Got about an hour into it.
It hangs down as far as the headers, so I'm not worried about clearance issues.
Should run the motor tomorrow or monday.
First drive may have to wait 'til weds.
High temp paint will last as long as it lasts.
KT
