I didn't do anything much myself on my car this past couple months, - but that is about to change - I did sort a short in the harness at the injector, replaced and injector, then drove the car 1000 miles to Connecticut , Manchester that is!!
Home of CFR , where there were many fine examples either completed or close, of some of Chris's work.
-ordered a front trunk seal from 914rubber,
-took car to CFR
on the agenda and already started as reported from Chris, with pictures in future
- began rust repair of rear longs and floor pan under drivers side,
- checking out engine
1. Compression numbers came back very good- @145-155 on all 4, and
I guess leak down was pretty good, going to be reevaluated once timing , valves etc get set or rechecked. - if my motor weakness is just a tuning thing, then I will be able to do a couple other things on that front rather than a rebuild:
a. sport header from CFR and SS performance muffler from CFR, with improved oil cooler from CFR,
Chris may post a few pictures of the rust repair, and the fender stretching/repair as it progresses.
expectation is to bring the car home once this stuff is done, and re-paint will be the next step- that may be by next month!!!!
- so the big vendor donation for this month by far is CFR - that deposit for work is what I paid for the car!!!
now on with the
