Now where was I ? I fell asleep with the computer on my lap.
With the wheelhouse opened up I have a better picture of the damage to the long.
Not going crazy like I did on my car. LOL. The outside will need a bottom patch. Looks like I can keep it inside the floor pan seat.
Click to view attachmentI'm cutting up to the heater tube because experience says I won't be able to weld the pitted metal. It's thick enough, but you cant get enough of the rust out of pits for a good weld.
Click to view attachmentNow on to the inner box where all the damage started. This will take some delicate surgery to remove the inner box without damaging the outer long. I think this will take my entire pile of die grinders, cut off wheels and the Dremel to get the job done.
Click to view attachmentThis piece will have to built in
two three pieces and welded. The issue is, can we create the ribs without a seam roller. MacGyver (Super In Law) says he can. Hmmm.
I'm thinking Tool Whore will have to dip into the saving account and order a bead roller. Looking at Woodward Fab at Summit and Eastwood. Leaning towards the Woodward. You can order the additional dies as you need them.
The rear suspension was removed for better access for the wheelhouse repair. I was going ask for Rick's guidance on doing a trick repair of the wheelhouse. Trimming the outside off the new wheelhouse and sliding it behind the suspension mount. Just not confident I could get the welds that I'd be happy him. So the mount will be coming off.
Suspension added to the cart. Mark stopped by to drop of a couple additional RD pieces and pick up Ken's toe hook. He added prepping his cars for WCR to the work list. One oil leak, one D-Jet tune up.
