Half Day on Friday .
Started with stretching the heater tube holes a bit. A little too tight.
Click to view attachmentUsed a left over portion of an exhaust pipe from another customers Toyota All Trac exhaust repair.
Click to view attachmentNeeds to be able to swivel to get the correct angle of the dangleJeff Hail said there would be blood. Wrap the center tunnel first.
Do as I say, not as I do.
Click to view attachmentCut my ear and put about 3 cuts on my head.
Like a dumbass I took off my welding cap.
Lots of fiddling to get it too fit.
Click to view attachmentOnce again these cars were hand built. +/- 3mm. Fit both halfs before you start fiddling. On Mark's car the firewall is little smaller than the opening.
Here's the left and right shot.
Click to view attachmentClick to view attachmentI would have liked to have put it in there in one piece.
But it would meant removing all the tubes. So we sawed it in half with the band saw.
Worked the left side first.
Click to view attachmentClick to view attachmentRight before leaving I slid the right side into place to see where we're at.
Click to view attachmentPlan is to slowly and patiently seam weld the two halves back together to make the seam invisible.
Two tacks, then cool to the touch.Then use the spot welder and weld in the top flange. Leaving the sides loose until we install the floor and passenger fire walls.
Today is a Dad's Garage day. Back to work on the Audi. Trying a little Liquid Steel on some broken plastic hangers for the transmission cooler loop. Then fill it up and test the new Fan Control Module.
Pulled the drivers front window frame last Sunday to replace the broken glass mount.
Easy deal. Well designed door frame. Repaired was built into the design.
