Got the horn functioning again on the blue car. Broken wire to the horn ring and a dead horn. Beep Beep.
Super In Law continues with the front trunk channel.
I spent the remainder of the day getting the engine ready to reinstall.
Siliconed up the new oil pressure sender.
Did this when I walked in the door so it could dry while I was working on the blue car horn.Zip tying harness up nice and tidy
Heat shrinking and tightening all open spade connectors
Installed new oil pressure sender
Torqued down impeller
Install flywheel,
new seals & bearingInstall clutch and pressure plate
Install transmission and starter
Cut down the over length exhaust hanging studs on the back of the transmission mounts.
Digging hole in muffler. Not completely thru, so I was pondering doing a small weld. But after hearing a little rust rattling around inside of the muffler I decided against it.
Mark showed up about quitting time with the new/shorter plug wires and some heat components. Between what he brought and what I have we'll get some heat flowing to the passenger compartment.
Click to view attachmentStart today with checking the plugs and installing the new BERU plug wires.
Then the car goes back on the lift to install the new Bilsteins all the way around.
I'll do the small patch under the pivot mount location.
Then we wait for the trunk pivot from RD.
