When we returned to the shop I did have an oil spot under the engine/transmission union. So out she came.
Diagnosis :
1. No O-ring flywheel seal
2. Top of oil pressure switch leaking
3. Seal under oil filler/vent box
So the question is, do we replace the crank seal behind the flywheel
while we're in there? Looks to be Elring. I have a Sabo coming from GPR.
The rear trunk will come off today. Right hinge bracket has come loose. We'll see if it can be reused. Engine lid needs some tension attention.
Click to view attachmentClick to view attachmentArrows indicate the location of the oil dye.Flywheel is on its last turning.
Shaved bolts. But clutch looks to be in good order. No sign of oil saturation.
I'll put Super In Law on the
clicking drivers door hinge. Everything in the door strap looks to be new. Hole on door side pin holder is wallered out.
Our usual course of action is using the biggest bolt the new strap will take. And some mini bushing from something we dig up out of the little drawers at ACE hardware. I've yet to see a right angle adapter small enough that would let you weld in the holes and re-drill them.
But its been a long time since I've looked.
