Well haven't seen a lot of progress though plenty has been happening. Here is a picture of my motor finally coming together. With the intake flipped the ac compressor wouldn't fit. Added some risers to the intake to make space. Upgraded my turbo & Fuel injectors. Relocated the turbo to the stock subaru location. Cut out more of my trunk for the turbo relocation. Everything has been long & drawn out. Not to mention expensive. Didn't intend to have so much work done by my wrench. Just changed so many things once I left it there. Mike does good work so in the long run it will be worth it. It will definitely end up much nicer than if I had done all the work myself.
I haven't updated this in a while & this isn't much of one.
