John2kx
Aug 30 2005, 04:12 PM
Roger,
Looks like your getting really close. The only thing I noticed was lack of a recovery tank.
Wish I were closer.......would really like to see your progress in person.
John
Andyrew
Aug 30 2005, 04:34 PM
Interesting thing your doing with the mufflers.
btw, I wouldnt worry about breakin anything with the trani or cv's with those tires under there....
That should prove to be quite the burnout mobile.... lol
Dr. Roger
Aug 31 2005, 10:30 PM
OK guys and gals....
It's running. And how???
Like CRAZY fast!
The Corvette muffs are in and look and sound fantastic.
I could have not done it without all of your help.
Including Miles, ...
Baaaaah. That's "thank you" in goat talk.
Now my sweetie pie, who knows this car may break down at any minute, wants to go driving on little getaways or day trips.
I can't wait.
Andyrew
Sep 1 2005, 01:24 AM
How could those 165's hook up?
GIve us an exhaust vid!!!!
I wana know what it sounds like!
redshift
Sep 1 2005, 01:32 AM
OH NO! First New York! Then New Orleans... now.. Right e'ffin' here is in trouble!
Speedy..
M
Dr. Roger
Sep 2 2005, 12:08 AM
QUOTE (Andyrew @ Sep 1 2005, 12:24 AM) |
I wana know what it sounds like! |
Amazingly those 165's do well in a straight line. I'm not shock loading the drivetrain right now. Heck the engine is barely broke in. I'm running it a little conservatively but as i develop more confidence i'm sure there will be more postings from me regarding wider rubber. =-)
I've never owned a car that handled so well. thats not saying much though.
Alritey then. Upon request, the exhaust video Andy.
http://home.comcast.net/~rogergrubb/newexh...haustsystem.wmv
neo914-6
Sep 2 2005, 12:35 AM
John2kx
Sep 2 2005, 07:15 AM
Roger,
Looks like all the hard work paid off!! Engine sounds great too.
Be carefull passing large trucks over 100 mph with those skinny tires. BTDT.......it was not pretty and I feel lucky to be here now. I'm sure you have already experienced, it takes very little to reach 100 mph now.
John
Andyrew
Sep 2 2005, 11:56 AM
Sounds great!!!!
Glad you got yours running!!
Sounds like you have a little tuning to do, A dyno will fix that right up.
We'll have have a little heads up on the freeway (50-80 or sumtin)
I wana know what your engine does compared to mine. (yours will obviously be faster when tuned, I dont have heads yet)
Andrew
feels good, dont it?!
Aaron Cox
Sep 2 2005, 12:04 PM
nice rumble. too cool.
get some meaty tires before you kill yourself
Andyrew
Sep 2 2005, 01:08 PM
Dr. Roger
Sep 2 2005, 02:02 PM
Andy and everyone,
I am in the market for a wheel/tire upgrade. On a budget. =-)
I want to stay 4 bolt for now because I can't afford the Carrera front end/brakes that I need soon.
If I was smart I'd do the Carrera front ASAP and put some temporary 5 bolt wheels on her until I can affford some wheels/tires I really like.
Easy is saying a Carrera front end will run me about $800........
Any suggestions????
Rand
Sep 2 2005, 02:41 PM
First, relax and enjoy your new ride a little. Take it easy, break it in, keep the ear to ear grins flowing.
Dr. Roger
Sep 3 2005, 12:53 AM
Todays shakedown cruise went something like this...
Took off for Berkeley Marina. Noted temps very slowly climbing.
I have the fans on a manual switch and they were on.
At the marina she topped out at 200 degrees.
Dr. Roger
Sep 3 2005, 12:54 AM
Bebe and her owner.
Dr. Roger
Sep 3 2005, 12:57 AM
Then we cruised up University Ave in gridlock traffic. Temps continued to climb. I got out of stop and go, took surface streets up to Spruce for a light climb up into the hills.
That's where the temps got too high. Had to shut her down.
One use left on AAA card...... for the year.
Now I really feel like a 914 owner.
McMark
Sep 3 2005, 01:06 AM
I have some steel five lug wheels you can borrow for as long as you want.
Dr. Roger
Sep 3 2005, 01:37 AM
QUOTE (McMark @ Sep 3 2005, 12:06 AM) |
I have some steel five lug wheels you can borrow for as long as you want. |
Mark, Dude.
I will definately keep that in mind. Seriously.
Now I need that winning lotto ticket for the front end... Seriously also.
Dr. Roger
Sep 3 2005, 01:47 AM
So here's what I think is the overheating culprit.
It does not have an enclosed shroud for cool air so warm air can recirculate. I think.
But I was also thinking that a well burped sealed system would still be fine as it is.
Guess not.
For the seasoned V8 guys, is this fan shroud OK? Modification suggestions?
Dr. Roger
Sep 3 2005, 01:49 AM
Exhaust wheel well holes big enough?
(note: only the finest zip ties were used to hold this radiator in place.)
turbo914v8
Sep 3 2005, 09:33 AM
The fans you have should work well. Your problem is that you MUST build a shroud that encloses the fresh air intake for the rad. Air will travel the path that offers the least amount of resistance. In your case the path of least resistance is over the rad. The shroud will make the air pass through the rad. I am surprised that you did not over heat sooner.
914GT
Sep 3 2005, 09:49 AM
Paul is right. And at low speeds a barrier between the intake and exhaust sides of the radiator is required to prevent recirculation. What you have now lets the heated air get pulled back through the radiator and that will severely reduce the cooling efficiency.
John2kx
Sep 3 2005, 06:29 PM
Roger,
I see two radiator caps installed (one front and back) with no recovery/expansion tanks to collect coolant. If your running your setup as shown in pics, your sucking air back into cooling system everytime you cycle from hot to cold in addition to loosing water.
My two quart expansion tank would easily increase level by over one quart during a heat cycle in summer weather. Without the expansion tank, this coolant is being pushed overboard.
Your fender cutout size is fine.
Shroud the front of rad. as already mentioned.
Do you have a additional opening in front of car other than what you cut out in trunk floor?
One other IMPORTANT thing..........unless you crossed your radiator hoses somewhere between the front of car and water pump, your plumbed up backwards, ie sucking out the top of radiator instead of bottom.
John
Dr. Roger
Sep 3 2005, 07:42 PM
John,
YOU get the grand prize for my secret mistake.... Yes the water pump is plumbed backwards..... to the radiator.
I'm going to switch the hoses up front tomorrow.
i'm thinking of going with a fiberglass setup up front to route cool air.
with what little experience i have, i should be able to do a decent job.
more updates to come.
i'm off the next 5 days for vacation. let's see if it gets done....
John2kx
Sep 4 2005, 09:48 AM
Roger,
Don't forget the expansion tank! With your "2" radiator cap installation, you should pick one to feed and receive from expansion tank. I recommend the higher point in your engine bay. For this to work you need to have the radiator cap in front to have a higher pressure relief or plug the overflow line. RH recommends a 16lb. cap with their cooling system. You could also go with a 20lb. cap in front and the 16lb. at your fill port and get the same results.
Connecting the radiator to pump correctly and installation of expansion tank may work without the front ducting but I doubt it. It wouldn't hurt to give it a try, just don't veer too far from home.
You could use cardboard, foam and duct tape to temporarily fab up a duct to see if the sizing and path work prior to spending several days with fiberglass.
Your system has got to be full of air given the plumbing error and lack of exp. tank. I recommend going back through the burping procedure outlined earlier to remove as much air as possible prior to hitting the road again.
John
Dr. Roger
Sep 5 2005, 12:29 AM
Just in case there's anyone lurking, who has never driven a V8 914, and is wondering what it's lke to drive one...
Well let's just say, my hands were shaking for a half an hour after going to get a video 2 miles away.
I never.........
This car is sooooo dang fast and fun to drive. I've been riding "go fast" bikes mostly, and lately, off road trail riding/moto-X.
I can't picture many fu-fu drivers behind the wheel of this beast.
Everything happens fast except the braking.....
Manual steering (albeit, light and responsive)
Clutch is light and consistent.
Throttle is very responsive but watch out for too much throttle... especially 'round turns. Simple left or right turns can become reverse lock turns at will.
Even starting out in third gear is almost effortless. Not for the clutch, obviously.
Bebe is my first 914 and I have no regrets doing this project.
Next: Buy stock in AAA. =-)
There is lots of work still to be done.
There are some issues with engine heat and shimming the starter just right.
Those issues will be addressed immediately.
Other than that she's a driver.
Thanks again all.
Bebe tucked in for the night.
Andyrew
Sep 5 2005, 12:47 AM
Yes, get brakes...
At least invest 200 bucks and get STICKY pads.
Oh, and 50 bucks in sheet metal and pop rivets.
OH ya, if you have a little nipple thing on the radiator fill.. you HAVE to either plug it off, or have an expansion tank on it.
Andrew
Dr. Roger
Sep 5 2005, 01:03 AM
QUOTE (Andyrew @ Sep 4 2005, 11:47 PM) |
Yes, get brakes...
Andrew |
WaddaUmean? Sheet metal and pop rivets???
Did someone say I wanted to flare Bebe? (secretly i really do) it's just a money thing.
Andyrew
Sep 5 2005, 01:16 AM
Sheet metal... and pop rivets... for a radiator shroud.
Andyrew
Sep 5 2005, 01:18 AM
Dr. Roger
Sep 5 2005, 11:07 PM
Well I must say, today was so crazy.
I had to give three friends rides and man, that was fun.... starting to push it a little harder. had another reverse lock turn.
i planned it though.
took it over to visit with some friends and then it got dark.
started her and turned the lights on and nothing happened.
then i noticed no lights worked on the entire car. except the green oil light.
everything worked yesterday...
took a chance and drive it home and as i was pulling into the garage, "Poof".
a flame was seen shining through where the ignition steering column goes through the dash. See pic. and red arrow.. OH SHIT< NOt in my f-ing garage.
I gave it a blast with the extinguisher and that was that.
electrical in nature as it stunk to high heaven. whatever that smells like .
upon furthur inspection i noted that the PO had sone some custoom wiring to the stereo and left other wires just exposed under the dash...
Dr. Roger
Sep 5 2005, 11:09 PM
John2kx
Sep 6 2005, 06:07 AM
Don't feel like the lone ranger and I'm glad she did not burn to the ground. Hope you don't have to go this far............
John
Dr. Roger
Sep 23 2005, 11:45 PM
starting fiberglass air ducting.
Dr. Roger
Sep 24 2005, 12:01 AM
And the details of the electrical fire....
red arrow points to where the harness was cut by steel support bracket for the steering column.
aparrently shorted a non-fused wire resulting in a little fire. fire exstinguisher is always by my side....... I strongly suggest everyone do the same.
Andyrew
Sep 24 2005, 02:32 AM
That ducting is a little low...
You might find yourself cursing every time you go over a bump..
I guess we'll see it tomorrow!!
Dr. Roger
Sep 24 2005, 09:38 AM
yea, i figure it's easier to take some off than add... bebe is still down with wiring issue so you'll see her next time. sorry.
Dr. Roger
Sep 29 2005, 09:52 PM
I was so inspired by the electrical fire, that I had to add some flames to the car. I don't know if it looks good or bad but it's better than the plain fiberglass that was going to go on there. =-)
No more blow-by or recirculating air.
Rand
Sep 29 2005, 10:53 PM
Burning Man special!
Way to go Roger. That will help keep her cool.
Andyrew
Sep 29 2005, 11:01 PM
wow...
How did you paint it?
shrouding looks good.
redshift
Sep 29 2005, 11:20 PM
Looks great dood!
I love it.
M
Dr. Roger
Sep 29 2005, 11:40 PM
QUOTE |
wow...
How did you paint it? |
hehhehhee.
clearance rack at the local fabric shop.
I used the same stuff on the back of my Burning Man Art Car/fur covered surf board seat, and the hat i wear when driving the board. =-)))
you don't HAVE to use fibered glass for the fabric. You can use many kinds of fiber if it's not too structural of an application. AKA eye candy.
Dr. Roger
Oct 3 2005, 11:52 PM
OK, back to work.
Figuring out how to get rid of them 31 year old wires and switches. It's coming along very slowly probably due to the fact that i'm no electronics wiz. Hey, one step at a time. Right?
One thing I do need to figure out is how to wire a relay. Like the blinkers and emergency flashers. And what's the purpose of the rest of the relays? Are they really needed? =-)
Got a call today and the new fuse box is in. P/U tomorrow. Yes!
Dr. Roger
Oct 11 2005, 10:43 PM
Don't let this happen to you.
Dr. Roger
Oct 11 2005, 10:46 PM
New fuse box just got in.
Nice clear front.
Expecting the marine grade rocker switches this week. They come with push button breakers but i'll just use the fused system.
Dr. Roger
Oct 11 2005, 10:49 PM
And from my Summit friends tonight...
Now the air cleaner will not clear the lid... oh well.
Shameful progress. I know.
Dr. Roger
Oct 21 2005, 05:40 PM
Little update.
Just received the Marine rocker switches.
Picked up some heavy gauge wire and spade connectors.
Main power shut off.
Feeling overwhelmed. Gunna' take a brake from this project.
Roger
neo914-6
Oct 21 2005, 06:32 PM
call me, if you're for hire...
Dr. Roger
Dec 18 2005, 04:11 AM
This whole, "being sick" thing is really getting me bored into action again. I mean on Bebe.
After the little electrical fire incident...
Tonights little project.
It works so sweeeeet.
Waterproof/Marine Main power switch.
