front didnt need 2" more like 1"...
looks good. i hope you know how to do body work on the rear
QUOTE |
front didnt need 2" more like 1"... |
QUOTE (rick 918-S @ Mar 18 2006, 09:48 PM) |
Don't leave the rivets in after the flares are bonded. They will expand and contract at different rates than the glass and read through the finish. Grind the unside of the steel Quarter panel and grind the inside of the flare and glas the inside as well as the outside. My flares have been bonded for over 10 years without a crack. edit; are you installing them like JP's? If so, disregard my post. |
QUOTE (turboman808 @ Mar 18 2006, 10:02 PM) |
Whats size is that in front? Will it work with 1 inch spacers. Looks really good.! But anyways can you post up the front a rear info. I couldn't find it all by going back. Thanks these are cool http://cgi.ebay.com/ebaymotors/18-Factory-...1QQcmdZViewItem |
QUOTE (Aaron Cox @ Mar 18 2006, 10:17 PM) |
ask JP about your new scrub radius looks like fun |
QUOTE (Dr. Roger @ Mar 18 2006, 10:24 PM) | ||
hmmm scrub radius.... yes, way different. i'm not looking forward to close quarters tight turns. JP, what's your experience here? once again, i'm hoping that there are so many people that have widened their front width that it shouldn't be THAT bad. right? the 1" spacers would have been fine but i wanted to give my fenders a little push out to match the rear width a little closer. |
QUOTE (turboman808 @ Mar 18 2006, 10:18 PM) |
Sorry Well I guess all of them. Mainly the tires and wheels. Those 18x8 are gonna work on the front with no problems? yeah I am in the middel of finalizing everything with the 914. I should have it in my possesion next weekend. |
QUOTE (Dr. Roger @ Mar 18 2006, 10:29 PM) | ||
with the 8X50mm offset of my rims, a 1" spacer is probably just right. your ebay rims are a 57mm offset so you might not need a spacer. i prefer my wheels to be right out almost touching the inner fenders. it's easier IMHO to but spacers and stretch the fenders to get the clearances just right. 914 fenders are not identical on each side as you will quickly find out. =-) |
QUOTE (Dr. Roger @ Mar 18 2006, 09:24 PM) |
once again, i'm hoping that there are so many people that have widened their front width that it shouldn't be THAT bad. right? |
QUOTE (Dr. Roger @ Mar 18 2006, 09:29 PM) |
i prefer my wheels to be right out almost touching the inner fenders. it's easier IMHO to but spacers and stretch the fenders to get the clearances just right. |
