The engine is in the car. It actually slipped right in without much bother. Greg had to loosen the engine tin on passenger side to get her in. We slipped the 993 chassis harness that connects the engine to the chassis in through the firewall in the same spot as the 3.2 harness entered and it fits nicely. Then hooked up both axles just because they were in the way and torqued them properly. Then Greg installed the breather hose from the oil tank filler to the engine.
The only concession I had to make to fit the air intake/MAF/filter where we wanted it to live was Greg had to remove the trunk torsion bars, (those puppies were under some serious tension). I will go with 2 hydraulic shocks to handle the trunk lid. I checked out Greg's 914-6 to see how they operate and they are nice. Removal of those 2 rods opened up enough space that the intake fits nicely and runs along the trunk bulkhead. We also removed the complete relay board assemble as we no longer needed that and it took up some serious space. I was actually bummed about that as I really like Auto Atlanta's (George's) new relay board cover and wanted to see that in the engine bay.
Overall, a really satisfying day; I am so so happy to see that engine in place. It's amazing how smoothly things go when you are working with a guy like Greg who knows what he is doing, has the tools to do it, and wants it to look as clean and tidy as possible.
Oh, we did de-boss the intake a bit to clean it up. Removed 3 large mounting tabs which held a large mounting bracket for some electrical connectors. Those connectors will live comfortably below the intake.
