Marv's3.6six
Mar 14 2012, 11:17 PM
My baby on her way to Precision Motion for the fun to begin. Engine and trans fitment to body begins next. I have waited so so long for this.
stuttgart46
Mar 15 2012, 06:33 AM
I don't think I could sleep until I got it back.
Such a great looking car.
TravisNeff
Mar 15 2012, 09:36 AM
SO HAVE WE!
QUOTE(Marv's3.6six @ Mar 14 2012, 10:17 PM)
Marv's3.6six
Mar 15 2012, 04:37 PM
I spent quite a while yesterday with Don from PMP. We discussed many aspects of the car.
One thing I am considering is running some beautiful 16" 930 Fuchs I have had for a long time instead of the 17" HRE that are on the car. I am thinking the 16's will look more period correct to the car with 50 and 55 series sidewall versus the super skinny on the car now??
Marv's3.6six
Apr 14 2012, 09:14 AM
QUOTE(Marv's3.6six @ Mar 15 2012, 03:37 PM)
Ok I have found out the offset on 930 fuchs are a no go, the wheels do not fit under the rear flares... time to ebay the fuchs.
Marv's3.6six
Apr 14 2012, 09:19 AM
Progress...... Patrick Motorsports front engine mount being welded in. The stock 6 front mount would be tortured with all the torque from the 3.6, ....had to go for the big guns.
PRS914-6
Apr 14 2012, 09:23 AM
I have the 9" 930 wheels on mine and they fit fine. What if you trimmed or rolled the lip on the flare? You could gain 1/2 inch or so.
Marv's3.6six
Apr 14 2012, 09:33 AM
Wevo semi solid rear mounts.
Marv's3.6six
Apr 14 2012, 09:40 AM
QUOTE(PRS914-6 @ Apr 14 2012, 08:23 AM)
Lips are rolled but would require some more work. At this point the 17's will be the way I will go, much more tire choices anyway... and the gear ratios I worked out with Jim Patrick on the trans are matched to my tire choice. And lastly I don't have the extra coin as it is being consumed on the project.
Marv's3.6six
Apr 14 2012, 10:14 AM
And here she is fresh as a daisy ready to go. She is a ROW 993 3.6 with RS cams, Patrick lightweight flywheel, RS Eng. match flowed fuel injectors, new valve guides, new racing valve job, new fly cut heads...... all ready to run the snot out of. Can't wait.
Marv's3.6six
Apr 14 2012, 10:34 AM
Last photo of the day. Here is my front valence/spoiler... On the left side is new 5mm alum black ano button head screws on the right the stainless hardware... the black ano looks sooooo much better.
0396
Apr 14 2012, 01:06 PM
QUOTE(Marv's3.6six @ Apr 14 2012, 09:14 AM)
Motor looks 'clean'.. congrats on your progress
jim dorociak
Apr 14 2012, 09:16 PM
Your wheels might look much more time period correct if only the outer rims were clear anodized instead of high polish. Here is a picture of the last set of 3 piece 17" fuchs I restored. jdorociak@gmail.com Jim
jim dorociak
Apr 14 2012, 09:18 PM
If I were to restore a set again I would use black bolts so they would disappear. jim
PRS914-6
Apr 14 2012, 10:26 PM
Just an FYI.....I started off with a Patrick crank pulley. It was the only single 993 pulley I was aware of at the time of my build and I didn't like it's smaller diameter and resulting slower fan and alternator speed. I later learned that the 993 RS had a single pulley system and the diameter was the right size. As you already know, every 3.6 needs a valve job and I believe it is because of the high heat generated by these engines and the smaller pulley is just an invitation to aggravate valve guide wear for little HP gain.
I have just installed the RS pulley in preparation of this summer.
Anyway, I only mention this in case you weren't aware of the availability of the larger Porsche pulley.
Apr 15 2012, 08:09 AM
QUOTE(PRS914-6 @ Apr 14 2012, 09:26 PM)
Click to view attachmentGreat info... where would one source this?
Thanks
PRS914-6
Apr 15 2012, 08:18 AM
QUOTE(396 @ Apr 15 2012, 06:09 AM)
Thanks
Porsche dealer. I bought mine 2 years ago for the same price as a Patrick pulley (now for sale) but the price has gone up some. You won't want to pay retail. Sunset Imports (Excellence readers discount) or similar can get it for you.
0396
Apr 15 2012, 08:23 AM
QUOTE(PRS914-6 @ Apr 15 2012, 07:18 AM)
Thanks
Thanks for the fast reply / info
Marv's3.6six
Apr 15 2012, 09:02 AM
QUOTE(396 @ Apr 15 2012, 07:23 AM)
Thanks
Interesting info I will check into it. But here is my uneducated thoughts on the issue. The valve guide issue with 993 is well documented and IMO is primarily because of soft valve guide material. Under driving the fan and alternator is probably not an issue on our cars as the cooling is most likely sufficient because most 914's do not have another 1000lbs of mass to push around, do not have air conditioning plus other parasitic devices and creature comforts all of which the 993 has. Additionally the alternator in a 914 application does not have to power all the electronic gizmos the 993 has, so it is less critical to spin the alternator at a higher speeds to keep the voltage and amperage high.
Marv's3.6six
May 19 2012, 09:05 AM
Front suspension completed and tight. check.
Brake work done. Hard lines, T's, Braided lines all finished. Brembo GTPLW brake system completed and ready to roll. check.
Marv's3.6six
May 19 2012, 09:18 AM
Engine and trans test fit. Looks good. Fit good. Getting closer. There is much more work to be done. Install throttle cable assembly etc. Fab a false bulkhead for the battery and 993 ECU wiring loom. I also did not like how the painted intakes turned out so I am redoing those.
Marv's3.6six
May 19 2012, 09:24 AM
Customized Porsche gauges installed. North Hollywood Speedo makes incredible stuff. check.
Elliot Cannon
May 19 2012, 04:32 PM
That's a really great car Marv. Whos is it?
Marv's3.6six
May 20 2012, 11:54 AM
QUOTE(Elliot Cannon @ May 19 2012, 03:32 PM)
Marv's3.6six
May 20 2012, 12:06 PM
New windshield installed. check.
This is the second windhield I have bought for this project. The first one was purchased in 2005 by my (not any more) friend Tom, we wrapped it up in blankets and stored it for future installation. Well Don from PMP went to install it and he discovered that it was a mercedes windshield! Tom f***ed me again! Anyway new windshield yay.
euro911
May 20 2012, 12:20 PM
Looking good. Interesting oil tank ... who makes those?Click to view attachment
Krieger
May 20 2012, 04:12 PM
WOW
Marv's3.6six
May 20 2012, 07:48 PM
QUOTE(euro911 @ May 20 2012, 11:20 AM)
It's an original 6 all factory parts.
Qarl
May 20 2012, 07:58 PM
Looking good!
Cairo94507
May 20 2012, 08:13 PM
I am loving this car....except for the wheels thus far (sorry). That aside, this is a terrific build and car.
euro911
May 20 2012, 08:49 PM
Maybe it's the angle, lighting or shadowing in the shot - it looked like an external tank sitting in the engine bay
... Just my old eyes playing tricks on me
Marv's3.6six
May 20 2012, 11:02 PM
QUOTE(Cairo94507 @ May 20 2012, 07:13 PM)
The wheels look much better in person. But yeah I kind of agree and have been thinking about refinishing the "polished" look to an "RSR" finish. My brother thinks they look great as is but I am considering change. I also have a beautiful set of 16" 930 fuchs, but have been recently told they won't fit over the brembo's.
The new 17" fuchs look wheels (Rota Fox) are beautiful but I also hear they are quite heavy. Decisions.
Cairo94507
May 21 2012, 06:55 AM
RSR finish......love it.
Mr.242
May 21 2012, 07:58 AM
QUOTE(euro911 @ May 20 2012, 07:49 PM)
I thought the same too. It because the relay board isn't mounted and in the way
GREAT CAR!
tavoman27
May 21 2012, 10:38 AM
QUOTE(Marv's3.6six @ May 20 2012, 10:02 PM)
Hi Marv... my 914 just got back from upholstery and its all new with the rs door panels you wanted to see... Car is at PMP and I will be working on it today.
Gus
Marv's3.6six
Aug 10 2012, 07:47 PM
8/10 The car as it looks today. Is all covered up for fabrication of custom roll bar.
Roll bar is a quasi replica of the factory 914-6 GT roll bar. Note that the bar is recessed back into the body and is well out of the way from a collision with my nugget. Roll bar fab by Don from PMP. very nice work, very.
Marv's3.6six
Aug 11 2012, 07:33 AM
Up close shot of roll bar a tight fit.
Marv's3.6six
Aug 11 2012, 07:37 AM
Battery now mounted next to the engine near factory location.
Marv's3.6six
Aug 11 2012, 07:40 AM
New braided stainless fuel lines.
Mike Bellis
Aug 11 2012, 08:41 AM
Make sure you can get the back glass in. Looks like a PITA with butyl rubber...
Aug 11 2012, 11:17 AM
QUOTE(kg6dxn @ Aug 11 2012, 10:41 AM)
Looks like a bolt in bar.
nine9three
Jan 28 2013, 03:29 PM
Marv's3.6six
Feb 9 2013, 12:35 AM
OK its time to post up recent work on my GT... I know its been a while so here are some pics.
1) New custom made (by Don) long wheel studs
2) Front suspension near completion
3) New high torque starter and with rebuilt CV's and freshly painted axles.
4) Beauty shot of headers & valve covers
5) pic of installed muffler & 2 beautiful 356's (The black one has a six stuffed in it)
Marv's3.6six
Feb 9 2013, 12:50 AM
Pics
1) Front suspension with sway bar completed. Drop spindle struts with decambered ball joints turbo tie rods bump steer kit. Sexy looking.
2) Another view of the muffler customized bracketry work and ceramic coated
3) Lower baffle for oil cooler
4) Pedal cluster installed and fine tuned.
5) Baffle shot
Marv's3.6six
Feb 9 2013, 01:08 AM
1) Recaro drivers seat installed. Lower rear seat mounting brackets modified rewelded to tub and seat lowered.
2) 930 steering rack completed
3) Porsche factory fuel filter installed
4) Patrick motorsports super beefy front engine mount completed
5) Clutch cable system installed and tuned
6) Oil lines completed and pressure tested
Cairo94507
Feb 9 2013, 07:40 AM
Now that is the way I like to start my day. Your car is looking beautiful. Very nice work
Elliot Cannon
Feb 9 2013, 06:57 PM
I think we all know that isn't Marvs car.
Nice try Marv.
euro911
Feb 9 2013, 08:13 PM
Nice looking stuff
Marv's3.6six
Feb 9 2013, 08:53 PM
QUOTE(Elliot Cannon @ Feb 9 2013, 04:57 PM)
Nice try Marv.
Photoshop virtual car.
L E OT
Krieger
Feb 9 2013, 08:59 PM
Very nice! Are you going to put it on the track?
