Well, we had guest speakers all day yesterday for my students so I left early and dropped off the Volvo at the dealer, it is creaking, and then went home and did some work on the Teener.
I finally broke down and picked up a remote starter, compresson tester and new timing light with advance. Yeah, I know, I should have already had these things.
I decided to pull the dizzy and start from scratch so as to line everything up properly. So, first order of business, pull the #1 plug and screw in the compression tester. Next, hook up the remote starter...not an easy damn task with the new starter! Finally, pull the dizzy.
Time to find TDC, using the remote starter and the compression tester made it a hell of a lot easier! Had I gotten these items before it probably would have saved me a lot of headaches early on while I was in Germany.
I re-marked TDC on the fan with white, it was already marked in red but much harder to see. Before I did this though, I crawled under the car to feel for the notch in the flywheel that should correspond to TDC on the fan. Yup, got it and the notch where the dizzy goes is also pointing in the correct direction. Looking good so far.
Now, time to re-install the dizzy, line up the rotor with the mark on the housing, check to make sure it lines up with a plug...fuck with it for the next 30 minutes trying to get it in and lined up properly!
I finally got it in and lined up properly after a bit though. Unfortunately, at this point I needed to head off to my welding class so didn't get much further.
Prior to putting the dizzy cap back on, I wrapped new white electrical tape around each tower so I can properly mark the firing order. Now, after some checking, firing order rotating clockwise is 1,4,3,2; clockwise direction is with me standing behind the car. Unless anyone says differently this is how I will proceed.
I will mark the cap accordingly but before I hook the wires up, I plan on running compression tests on each cylinder first. Then I'll hook up the wires and see if we can get her to crank. I'm hoping that re-setting everything to baseline will do the trick, if she starts then I'll work on re-timing the motor and then balance the carbs. Wish me luck, i'm gonna need it!
