Subaru Engine Conversion Wiki, Let's compile all the knowledge into one thread... |
Britain Smith |
Sep 9 2010, 10:59 AM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Oil System
- Different Sump Pans Outfront sells a shorten oil pan for $270 which included a shortened pickup tube. They also list a mid-engine pan for $370, but I am not sure what the difference is. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.outfrontmotorsports.com-364-1284054502.1.jpg) Here is a nicely modified pan from TonyAWAVW with side kick-outs. Bugat5Speed (http://www.bugat5speed.de/en/) offers a cast aluminum sump. Details: Some Product Details: -Works with EJ 2.0, 2.2 and 2.5 blocks -The sump is sandcasted like all our other parts. -The capacity of oil is 4,25 litres (that´s only 0,25 less than original). If you shorten an original sump you loose about a 1 litre. -It is very stabile (you can put a hydraulic lifter under it and lift the car), so nothing happens if the car is low and the sump hits the floor). If you have the original sump, that´s virtually impossible. -The cooling properties are much better than with the original one. Water temperature is reduced by about 10 degrees Celsius, if you switch from original to the bug@5Speed sump. -The pick-up tube inside the sump must be modified (shortened). But that´s no big deal. Anyone who does such a project will easily handle this task. -The original dipstick can be used, but must be shortened a little. - Overall dimmentsions are 275 x 320 x 120 mm (length, width, height). *** One key point, these sumps will interfere with the stock motor mounts, if your using the RJES conversion. Will require modifications of mounts. (IMG:http://www.914world.com/bbs2/uploads_offsite/i78.photobucket.com-364-1284134624.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i78.photobucket.com-364-1284134625.2.jpg) Small Car Performance also sells a cast aluminum pan. Link Features * Thickwall alloy aluminum for handling the worst conditions * Stock Subaru oil capacity (4.3 liters) or 5.5 quarts when filled to the later Subaru level * Shaped bottom for superior oil scavenging * Finned exterior for heat dissipation * Heliarc welded screened oil pickup * Stainless bolts with aluminum washers * Comes with o-rings for the oil pickup and for the stock or our flexible dipstick * 4 5/16" total height saves over 2 inches when compared to the stock Subaru oil pan (IMG:http://www.914world.com/bbs2/uploads_offsite/www.smallcar.com-364-1284136350.1.jpg) - Dry Sump Set-up Not sure if it is needed, but some have converted to dry sump set-up. The expense of this set-up can exceed $3K and is very complicated. (IMG:http://www.914world.com/bbs2/uploads_offsite/dragracevws.com-364-1284054503.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/dragracevws.com-364-1284054508.3.jpg) |
Lo-Fi Version | Time is now: 18th May 2024 - 02:24 PM |
