michelko
Apr 9 2005, 11:03 AM
stretqetq
michelko
Apr 9 2005, 11:04 AM
and battery tray in place
michelko
Apr 9 2005, 11:05 AM
erteqrzqe
michelko
Apr 9 2005, 11:06 AM
last one for today
cheers
Jeroen
Apr 9 2005, 11:11 AM
once again... excellent job!
michelko
Apr 30 2005, 10:40 AM
hi together,
while waiting for the tie coat primer to cover the por 15 areas i fixed another little hole. I pulled the tank. Nothing big. Came out just fine.
michelko
Apr 30 2005, 10:41 AM
nother view
michelko
Apr 30 2005, 10:42 AM
the patch
michelko
the patch held in place
michelko
Apr 30 2005, 10:43 AM
and welded in
michelko
Apr 30 2005, 10:44 AM
view from inside the car
michelko
Apr 30 2005, 10:45 AM
the rest of the tank compartment is in good shape no need to weld
michelko
Apr 30 2005, 10:46 AM
ert
michelko
Apr 30 2005, 10:47 AM
wretre
michelko
utezutz
michelko
Apr 30 2005, 10:49 AM
cleaned up the engine compartment with marine clean. this is realy good stuff
michelko
Apr 30 2005, 10:50 AM
better shot
michelko
Apr 30 2005, 10:51 AM
an the hell hole area, ready to get some primer on it.
have a nice weekend
michelko
May 8 2005, 06:39 AM
Hi everybody,
in the meantime i grinden out the old Primer/rust/dirt mix on the floor panel.
Today i gave it a por 15 coat.
The difference is realy impressive with a clean surface and one stage more with the primer on.
I hope i can take a ride the next weeks
michelko
May 8 2005, 06:40 AM
#2
michelko
#3
michelko
May 8 2005, 06:41 AM
ooops
michelko
May 8 2005, 06:42 AM
#4
michelko
May 8 2005, 06:43 AM
and the nice new pedal cluster waiting to get connected
CptTripps
May 8 2005, 07:11 AM
You are getting close man....doesn't it feel great!
Keep it up...you'll be on the road in no time...
michelko
May 15 2005, 02:51 AM
Hi together,
this weekend i did the driver side. Metal ready and Por 15 on the floor.
I also wrapped the cables with new textile band (don´t know the right name in english
michelko
May 15 2005, 02:53 AM
this por 15 is realy great, i love that stuff. Better than a i testet till now
michelko
May 15 2005, 02:54 AM
nother
michelko
May 15 2005, 02:55 AM
cable work
michelko
May 15 2005, 02:56 AM
with pedal cluster
michelko
fdghsd
michelko
May 15 2005, 03:00 AM
and the seat adjuster newly plated.
Now i am waiting for the ordered stainless steel fuel lines.
I am thinking on relocating the fuel pump. I can´t get a working old style pump, and the new stile didn´t fit in the engine compartment
CptTripps
May 15 2005, 06:48 AM
Great work man!
My fuel pump is up front, I'm not sure that I like it up there, but we'll see. As soon as I turn the key, I can hear it running...SHOULD it be like that...I don't know.
I *DO* know that your car is looking fantastic. Have a 'Goal Date' in mind to drive her?
michelko
May 15 2005, 12:59 PM
QUOTE (CptTripps @ May 15 2005, 04:48 AM) |
Great work man!
I *DO* know that your car is looking fantastic. Have a 'Goal Date' in mind to drive her? |
Thanks for the flowers,
but your work is also impressive . After i saw your paint job i decided to try this part too.
I think you can hear the pump anyway front or rear for a couple of seconds.
Goal for driving is asap.
To get the engine in, i have to paint the engine bay. Don´t want to pull the engine a second time to get this done.
Tie coat primer arrived last week, and i have to buy some (adriatic-) blue paint to complete this part.
I think the compartmment is a nice practice ground.
So i think first drive out could be end of june?! Hope so.
When didi you drive yours again?
michelko
May 22 2005, 02:01 AM
Hello all,
this weekend i removed the poorly repaired engine bay hinge on the driverside.
the hood was about 5 mm lower then on the other side. Someone has used some solder instead of welding the broken part
michelko
May 22 2005, 02:03 AM
the passenger side, also rusted but in good shape.
Have only to clean it.
michelko
May 22 2005, 02:04 AM
driver side out of the car
michelko
May 22 2005, 02:06 AM
and here is the new one. look much stronger than the part i drilled out. I think it is not an OEM part
michelko
May 22 2005, 02:07 AM
welded in
michelko
May 22 2005, 02:10 AM
last week i drilled the holes for the front sway bar.
this weekend i cutted out the sheet metal to put in the reinforcement plates.
Driver side.
You can also see the new cable for the relocated fuel pump.
michelko
May 22 2005, 02:11 AM
passenger side
michelko
May 22 2005, 02:12 AM
cutting the opening
michelko
May 22 2005, 02:13 AM
without the plate
michelko
May 22 2005, 02:14 AM
view from the wheel side
Lou W
QUOTE |
michelko Posted on May 15 2005, 02:00 AM and the seat adjuster newly plated.
Now i am waiting for the ordered stainless steel fuel lines. I am thinking on relocating the fuel pump. I can´t get a working old style pump, and the new stile didn´t fit in the engine compartment dry.gif .
Where are you getting the new fuel lines from?
Are you going to paint over the por15 that you applied on the interior floor boards?
Keep up the great work.
michelko
May 22 2005, 02:15 AM
Plate welded in and the hole closed
michelko
May 22 2005, 02:16 AM
same procedure on passenger side
michelko
May 22 2005, 02:17 AM
welded and closed
michelko
May 22 2005, 02:19 AM
and the last one view from wheel side again
Lou W
QUOTE |
michelko Posted on May 22 2005, 01:10 AM last week i drilled the holes for the front sway bar. this weekend i cutted out the sheet metal to put in the reinforcement plates. |
Did your car have the original factory swaybar upfront?
