QUOTE(Andyrew @ Dec 24 2012, 08:50 AM)
Dont use an OBD scanner use a VAG-COM scanner. Its like an OBD scanner that you can read and monitor every electrical signal... The ECU shouldnt miss anything except maybe the climate control... You might want to have that plugged in and just sitting somewhere, I mentioned to you earlier that you can monitor some settings via this (at least in the Audi you can..). But its an intuitive system so Its the only one that scares me that you say your going to not have in place.
Crazy work!
The scanner that I have will do all of that. it's not one of those simple scanners from a FLAPs. You use a laptop with it, and can see all sensors and datalog. It's based on the STN1110 chip set, and supporst the ELM327 command set. You can monitor almost every sensor, and if you have the command code, you can access the sensor if it's not in the standard codes.
From the webpage:
The free feature-packed OBDwiz diagnostic software included with the scan tool allows you to:
•Turn off check engine light, and erase stored diagnostic information
•Read and erase stored, pending, and permanent trouble codes (both generic and manufacturer-specific)
•Access freeze frame information
•Display, graph, and log 90+ real-time parameters
•Create custom digital dashboards
So, what is missing from the scanner that I have? I can probably write something to make up for what is missing.
-- brett
