They don't look too bad from the outside...
Here you can see 3 layers of sheet metal.
Here you can see 1/2" of bondo. White painted fender makes it look thicker.
I picked up a full set from AIR and 914 LTD. I also picked up some black fender welting. right now I just have them screwed on. I have wide rivets for later down the road. I was bidding on Brad's set (including rockers), lost the bid, bought a set from AIR and then Brad sent me a second chance offer. Now I have 2 complete sets. I already had flared steel rockers but realized the length of each was not consistent. Looks like the PO installed the old flares and built the rockers to fit. All of the old flares were off set different from the opposite side; Asymmetrical. The worst was the front right which was set back a full inch from the left.
So... I installed the new rockers first and installed the flares to meet. The jack post hole was the original alignment point. The ones I chose to install are from 914 LTD. The quality of both were good. The fit was almost the same. The 914 LTD flares were slightly thicker than the AIR's. I did notice that the gel coating on Brad's is cracking. I will deal with this someday when I paint the car.
If anyone needs a set of 4 fiberglass flares PM me. I will sell them for cost. I also have some free steel flared rockers if anyone wants them.
