I got the Phantom Grip(PG) installed today. I did have to machine the drive gears and the spider gears for clearance. I drove to several machine and gear grinding shops today. None of them could do the job. No way to chuck them up in the machine. So I did it myself. I built a drill rig from a bolt and some washers. The drive gear has a recess on the face for the stub axle circlip. I chucked up the gear in my drill and while spinning at low speed, ground it on my bench grinder. I took my time and kept eye with a caliper and straight edge. It turned out better than I expected. Looks like a flat machine finish. I also had to clearance the PG axle hole a little. Since I machined the drive gear, the stub axle sticks through a little further. I opened the hole in the PG to allow the stub to slide in without binding. Normally the end of the stub would be in the empty center void.
2mm off the drive gears
1mm of the spiders
1mm clearance inside the PG
Light tapping into the 3rd member and done. Overall the quality of the PG seems good. The theory looks sound and the fit is snug. If I take the springs out, the system turns freely, no binding.
I took some measurements in case somebody wants to try to fit this into a 901
Fully collapsed springs in my vise
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentMost of the area machined has no impact on function. Only a tiny bit of the contact surface was machined, verified by the wear marks.
Click to view attachmentClick to view attachmentInstalled. You can see the springs within the unit. These push on the drive gears to limit independant movement. It is very tight and cannot be rotated by hand. Once installed and wheels on, I will try to spin one wheel and see how much give the system has.
Click to view attachmentLooking into the drive gear splines. In the above picture of the gear you can see the recess for the circlip. I clearanced the PG so even the clip could go through. The stub stops on the top edge of this view. It has a shoulder the prevents the stub from going too far into the diff.
