QUOTE(gryphon68 @ Oct 22 2013, 09:53 AM)
Very interesting build thread. Interesting alternative to the Subi-swap for those looking for modern liquid-cooled power and smooth shifting.
My apologies if I missed the answers somewhere, but was curious about the two comments above.
First, why the Boxster axle stubs instead of the Audi's if you were doing custom axles?
Second, what was the issue with the axle angle? Was it due to the height or the length of the engine? Are the axles on the 6-speed in a different location relative to Rear face of Block compared to the 5-speed? Or did the 6-speed just allow the use of 930 CV's which should be more tolerant of the large axle angle (which is unchanged from the 5-spd?).
Thanks,
I mounted the engine and trans as far forward and as low as possible in the chassis. This was to maintain the F/R balance of the car. By doing this, the transmission output flange is no longer lined up with the center of the swing arm axle stub. The tranny is forward. Additionally, the car is lowered and the transmission is lower, This raises the swing arm stub center while lowering the tranny center. Thus creating a compound angle on the CV's.
The total angle was at the limit of the 100mm 944 CV joints (22°). So I switched to 108mm 930 turbo CV's. These have a max working angle of 30° and these are used by high power sand rails. A sand rail operates at severe angles all the time.
Audi makes a 100mm and a 130mm axle flange. The Boxster S/Cayman S 6-speed has 108mm flanges. Early 911 swing arm stub axles are 108mm and a direct bolt on for my 5 lug conversion.
I could have modified the Cayman S transmission stub axles to fit into the Audi tranny with a simple spacer but none of the dismantler's would sell them too me. They are $400 each from the Porsche dealer. I found a complete Cayman S transaxle in England and had it shipped to me for a total just under $1000.
The 6 speed has better gear ratios and the flanges I needed. Win, win for me.
The custom axles are off the shelf EMPI units from Pacific Customs. They cost $275 and each one is a different length. Both sides splined for 930 CV's. No custom machine work required and they can handle more HP than I will ever have.
To summarize, This was done with all bolt in parts. Even the shifter and cables are off the shelf units.
