Well it's going under the knife again. When I originally installed the Audi motor, I mounted it as low as as far forward as possible. This became my Nemesis. I have been fighting axle angle for too long. Every time you fix something, you find the next weakest link. I now have axles and CV's that are stronger than almost any force my car can give. But the angle is steep, 15-20°, maybe more under compression.
The next weak link... The Boxster tranny (5 & 6 speed) use a circlip to keep the stub in the tranny. The axle angle is now causing it to "walk" out of the tranny after 500 miles or so. It pops right out of the diff and spills fluid on the ground.
I just took some measurements of the car and have determined I need to move & rotate the engine/tranny combo. It will move 2" to the rear and the end of the tranny will be lifted 2". This will put the axle in a better but not perfect position. The 6 speed is much longer than the 5. If I move it back any further, the exhaust will hang out too far.
This pic shows the present position (red) and the future position (green). I only need to rebuild the motor mounts and reuse the cradle. Then I have to move 100 other things connected to the motor, inter cooler, turbo, exhaust, MAF, fuel lines, methanol tank, trunk floor, and everything else that pops up.
Good news: I'm not swapping the motor out. It runs great, needs nothing except to flash out my ABS brake alarm.
Now I have a summer project...
