Well I've been playing with my boost controller. What a PITA! You would think that just following the instructions, perfectly! would yield the desired result... NO!
Started the install just like the diagram on the left. Connected
exactly as pictured. The boost would peak at 12psi max. I then replaced all my vacuum lines. Same result. I double checked the entire system for leaks. None found.
Click to view attachmentI then added a vacuum line as described on the bottom left notes. Max boost... bla, bla... Connect a line from the manifold to the wastegate can... Took it for a test drive and it immediately peaks to 30psi. No ramp up, just straight to 30psi and is virtually undriveable. In addition I broke down on the freeway (my testing ground). At 30psi the cap on the power brake fitting blew off and the car stalled. It took a few minutes to get it started, I then found the massive vac leak. I quickly wrapped the fitting in electrical tape and limped home.
Frustrated, I removed all the vac lines and drove without a connection to the wastegate. It again peaked at 30psi but was a smoother ramp, yet still quick.
Almost at my wits end, I swapped the #1 & #2 connections on the boost solenoid. NOTE: this should not work. It's now backwards. Well, it runs better than ever. Nice boost ramp to 20+psi. Drives perfectly! I'm not sure what's going on with my boost solenoid. Either there is a typo in the instructions or I was supplied with a N.C. when I should have got an N.O. device (or vise versa).
Either way, Holy shit!!!! This 914 hauls ass!!!!! Way faster than my V8 and very close to the rotary but with more torque! So it feels like more power...
Now I need to get the axle and new tranny settled before I break something. The V6 Passat has the same gear ratio (almost) as the Boxster. The difference is .001 ratio per gear. The price difference between them is incredible. Used Passat tranny is ~$400. Used Boxster tranny is ~$1800. These are almost the same tranny, both made by Audi.
Both final drives are 3.70. My 1.8 tranny final drive is 4.11, should make all the difference...
Click to view attachmentI also added some hood pins. My original latch was removed to clear the intake manifold and now won't fit. I drilled and tapped the roll bar and then welded a nut in place. This way I can adjust the height.
Click to view attachmentClick to view attachmentI also received my 5 year award from the PCA. Overall I have been a member longer but took a hiatus for a while...
