Finally finished welding the floors. I took JPs advice and seam welded the
whole seam down the longs from the front of the car until past the transmission
dog bone intersection. Firsr ground it even and then welded it 2 inches at a
time. I welded only six or so sections a foot apart each day.
There is a lot of crap in those seams because the first weld session popped like
crazy. It was constant fireworks. Next day I welded the same sections again
and then I could get a good weld. Like I had to cook all the crap out of the seam
the first pass. Then I lightly ground the top and both sides. After that I filled in
any areas that had gaps, holes, or looked weak. Very time consuming.
Welded on the floor pan triangles and jacking points. Cleaned it all, etched
it, and epoxy primered it today, the first new paint on the car.
Click to view attachmentMade 16 gauge reinforcing plate for the anti-roll bar mount. The sheet metal on both
sides was torn in this area.
Click to view attachmentEverything will get seam sealed and primed again.
John
