I have reached a major milestone: the fuel and oil lines in the front of the car are all
made up and attached for the first time!
Of course, it will all come apart again for painting later...
I did not like the way the fuel system routing was working out. The lines were too
long and I did not like having any fuel system components in front of the fuel cell. So
I took it all apart and did some measuring and mock ups.
Click to view attachmentI realized I could make it all fit under the cowl, much like how the original builders had
it set up. Here is how it turned out:
Click to view attachmentUsing the old fuel lines I was able to make up all the new lines without having to use
any new AN line, except for the lines connecting to the Tangerine Racing fuel lines with
AN fittings from Chris Foley. I needed several feet of new line for each of those. I can
make the -6 lines with fittings at both ends in about 10 minutes or less (total guess).
I never really timed it but it does not take that long per line.
I will add Adel clamps or bolts to hold each component place. I will attach the fuel
lines in strategic places so nothing can rub on the steering or sway bar, etc.
Click to view attachmentHere is a diagram of the layout fuel system. I realize if I put the front of the car at
the bottom of the diagram it would match the photos better. You get the idea. The
check valves are there so that if one fuel pump is dead or turned off, the other one
can still pump fuel without it just going back into the fuel cell.
Click to view attachmentI also changed the routing of the oil lines so that the oil goes through the oil filter
before going to the thermostat and radiator. Someone made that suggestion, can't
recall who, but thanks for the tip. Here is a diagram of the oil line layout.
Click to view attachmentReally stoked to have this part done.
John
